![]() | Home > General (L494) > L494 TPMS question |
Best way to find out is let the pressure out of the spare & see if it comes up on the dash,(spare tyre low pressure) If it does then it is fine to go,pump the tyre back up till you need it.Their is a sensor detector in the boot for the spare. Andy.
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
I don’t think I have that, when I had my space saver on and no spare, I’m sure the only alarm was for the wheel position. Joined the X5 45e club
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
the manual says that the sensor will be picked automatically.. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Mine came with the full size spare so it will have already been programmed,I didn’t realise you had a space saver before,space savers don’t have the sensor fitted. Andy.
May need the bead broken again on the tyre so you can read the eight digit I.D code on the sensor unless you happened to write it down first before fitting it.
It’s in for a service next week, so will get them to do that.
For future reference, my new TPMS monitor didn’t need coding to the car, just a quick drive and it sorted itself out. Just don’t know if I have a boot sensor, maybe just let the tyre down and try it Joined the X5 45e club
That’s what I did Dave,let the air out & it should come up on dash,,spare tyre low pressure. Andy.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1191 ![]() ![]() ![]() |
Chaps, how do I check if my spare has TPMS fitted?
if it has a rubber valve then it hasnt.. |
^ thanks, will check it later |
TPMS is a grey hard stem with a nut like this
