![]() | Home > Faults & Fixes > Steering wheel feedback/wobble/pulling/wandering/heavy |
I haven’t had your issues but remembering some posts a while back. Wheels bearings were a hot topic and even though grabbing the road wheel and nil wobble detected a new wheel bearing solved the issue. Thoughts on warped discs. Some us get a first start of the day wobble which disappears after a mile or so.
DOCKER1LL Member Since: 08 Jul 2020 Location: Cambridge Posts: 6 ![]() ![]() ![]() |
Hi thanks for the reply, Ive had the car going on 2.5 years now. I bought it at 55k mileage and it was perfect, no issues whatsoever until around 6 months ago, the car has now done 105k miles.
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 ![]() ![]() ![]() |
Bent/twisted chassis rails perhaps??
Chugga90 Member Since: 25 Aug 2014 Location: Bucks Posts: 34 ![]() ![]() |
You have chased most of the same parts as my 2013 D4.
Just thinking about your issue. With that list unless I’ve missed something, could it be a sticky caliper on the near side pulling it left. Can’t think of much else. 2006 2.7 TDV6 HSE in Cairns Blue. |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
I second that thought, a sticking caliper will give most of those issues.
It could potentially be that, I will get that checked out on monday, but to be honest having driver the car daily with the problems above, it feels like a suspension issue? I have very limited knowledge at the moment but learning quite fast!
So I have the car back now after more investigation work and have had the following completed
Another thing to note... I have noticed the boots on both front air springs are missing and the area that is supposed to be covered is all rusted. I haven’t removed them and neither has the previous garage that did the work on my car, seems suspect? |
There are no boots on the front air springs. They are only present on the rear |
How is your power steering pump? Does it make the usual noises when turning full left to full right? 2019 5.0 SC SVA (Current)
Steering pump is ok. Ive just changed out my wheels as they were buckled. very big improvement but something is still off, not 100% |
One thing that hasn't been mentioned above are the track rods (inner and outer).
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Did I miss it when I read through this thread or did you check/replace your wheel bearings? Not a huge job and worth considering in my view.
