Home > Faults & Fixes > Steering wheel feedback/wobble/pulling/wandering/heavy |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
I haven’t had your issues but remembering some posts a while back. Wheels bearings were a hot topic and even though grabbing the road wheel and nil wobble detected a new wheel bearing solved the issue. Thoughts on warped discs. Some us get a first start of the day wobble which disappears after a mile or so.
Thu Jul 09 2020 6:49am |
DOCKER1LL Member Since: 08 Jul 2020 Location: Cambridge Posts: 6 |
Hi thanks for the reply, Ive had the car going on 2.5 years now. I bought it at 55k mileage and it was perfect, no issues whatsoever until around 6 months ago, the car has now done 105k miles.
Thu Jul 09 2020 4:08pm |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 |
Bent/twisted chassis rails perhaps??
Thu Jul 09 2020 5:53pm |
Chugga90 Member Since: 25 Aug 2014 Location: Bucks Posts: 34 |
You have chased most of the same parts as my 2013 D4.
Thu Jul 09 2020 7:31pm |
Just thinking about your issue. With that list unless I’ve missed something, could it be a sticky caliper on the near side pulling it left. Can’t think of much else. 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Jul 09 2020 8:00pm |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
I second that thought, a sticking caliper will give most of those issues.
Thu Jul 09 2020 8:33pm |
It could potentially be that, I will get that checked out on monday, but to be honest having driver the car daily with the problems above, it feels like a suspension issue? I have very limited knowledge at the moment but learning quite fast!
Fri Jul 10 2020 2:01pm |
So I have the car back now after more investigation work and have had the following completed
Wed Jul 15 2020 6:27pm |
Another thing to note... I have noticed the boots on both front air springs are missing and the area that is supposed to be covered is all rusted. I haven’t removed them and neither has the previous garage that did the work on my car, seems suspect? |
Wed Jul 15 2020 7:35pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
There are no boots on the front air springs. They are only present on the rear Kev
Wed Jul 15 2020 11:29pm |
How is your power steering pump? Does it make the usual noises when turning full left to full right? 2019 5.0 SC SVA (Current)
Thu Jul 16 2020 7:26am |
Steering pump is ok. Ive just changed out my wheels as they were buckled. very big improvement but something is still off, not 100% |
Sat Jul 18 2020 6:45pm |
One thing that hasn't been mentioned above are the track rods (inner and outer).
Thu Jul 23 2020 9:33pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Did I miss it when I read through this thread or did you check/replace your wheel bearings? Not a huge job and worth considering in my view.
Fri Jul 24 2020 6:38am |
