![]() | Home > Technical > parking brake fault after fully closing |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
I think you need to explain More |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
so i swapped out one sides brakes shoes and discs.
You only need to have 1 wheel up.
You may have to do this
Ahh perfect, I also have gap iid tool which has its own unjam procedure so fingers crossed there |
All sorted ta. What happened was the parking brake cable slipped out of the enclosure cause I did it wrong so the cable is fully shut hence the noise from the motor. I just need to replace on of my wear sensor cause I broke it and slam dunk.
Forgot the choc was there? |
yeah i drove forward and slightly bent the choc |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I've driven over my chocs a few times |
put it on the back of the "on charge" sign ! |
