Home > Technical > parking brake fault after fully closing
mgrover
quick question, changed the brake shoes and disc, i had to leave adjuster fully closed because cars not up on a ramp Sad
is the above why the cars throwing a parking brake fault? ie it just needs adjusting, or do I get the discs off and see whats what.
Post #601237 Fri Jul 03 2020 6:14pm
I think you need to explain More
Post #601240 Fri Jul 03 2020 7:12pm
mgrover
so i swapped out one sides brakes shoes and discs.
during this only the wheel i was changing is off the ground.
so i couldnt position the hole for brake shoes adjustment since it would attempt to move all 4 tyres when i tried to turn the one i was working on.
so i left the knurl fully closed.
when i turn on the car it throws parking brake fault and makes a noise like a cat is screeching, i assume the issue is because its not been adjusted and i haven't actually broken anything.
i will adjust it when i do the other side and get some heavy duty jack stands.
Post #601241 Fri Jul 03 2020 7:16pm
You only need to have 1 wheel up.
Jack car up. Put axel strand under 1 side for safety
Choc front wheels. Choc in the boot floor
Put gear selector in N
Park brake off
Remove key.
Should really remove P brake fuse to prevent any cat sceeetch probs
Now wheel will rotate
Post #601247 Fri Jul 03 2020 8:05pm
You may have to do this
Good luck !
https://www.disco3.co.uk/forum/epb-repairunjam-relatch-91299.html
Post #601249 Fri Jul 03 2020 8:12pm
mgrover
Ahh perfect, I also have gap iid tool which has its own unjam procedure so fingers crossed there
Post #601251 Fri Jul 03 2020 8:21pm
mgrover
All sorted ta. What happened was the parking brake cable slipped out of the enclosure cause I did it wrong so the cable is fully shut hence the noise from the motor. I just need to replace on of my wear sensor cause I broke it and slam dunk.
The neutral tip made it all happen although I did bend one of my chocs Sad drove onto em
Post #601278 Sat Jul 04 2020 4:38pm
Forgot the choc was there?
Post #601285 Sat Jul 04 2020 6:21pm
mgrover
yeah i drove forward and slightly bent the choc Razz wear sensors done as well. squealing hasnt gone though. it is much better
Post #601288 Sat Jul 04 2020 6:33pm
Eaters
I've driven over my chocs a few times Sad . I think I need to make a sign to hang on the steering wheel reminding me they are there! Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #601299 Sun Jul 05 2020 8:03am
put it on the back of the "on charge" sign !
Post #601315 Sun Jul 05 2020 10:48am
