![]() | Home > Technical > suspension connection |
Simonhunt72 Member Since: 13 Jan 2019 Location: Somerset Posts: 68 ![]() ![]() ![]() |
Update, now getting unable to adjust height randomly, and sometimes red warning, any help guys would appreciate it |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
Suspension module is above the driver's foot well, can be easily accessed by removing the panel immediately above the pedals.
Hi, thanks for the reply, no red lines on display, would it be good to check the connections? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Do you have a fluid bottle by the air filter box ?
A 2006 4.2 supercharger, yes i believe there is and I did check that a while ago |
The ACE system can trigger a red light. So you may want to read the ACE ecu to see if that has codes / clues
Had a reader on it recently ,lots of ghost codes!!! But nothing to state an issue! And was unable to clear yellow lean light, it does seem to be random!!! But light has not gone off for a while now , and normal height only is more frequent. So may i ask what would be in passenger foot well , where it all got soaked |
I guess the wiring from the switches goes via the passenger footwell
Well sounds like the place to start , will keep posting updates ,thank you for your help andyk |
So ,update, came out in the week to find rrs on its knees , back still up, will not raise the front , checked for leaks on back valve block ,nothing , compressor runs for a short time and is very noisy! Would it be a good shout to check the front block or bite the bullet and replace the compressor, as a good search through other feeds points to this being the probable fault, any help greatly received as always ,tia |
Sounds like the compressor needs a service.
Thank you Andy, got the darn thing raised, compressor still runs after good minute or so in off road , also had raising slowly, and will raise when system cooled . Found a receipt for Feb 2019 ,so called new amk unit fitted |
So its been raised all night , not dropped one bit , hopefully pointing to no leaks , think replace compressor |
So ,chatted with garage today, confirmed the compressor runs too long and is noisy!! Receipt i have says AMK ,and fitted Feb 2019, what would you guys recommend as a good replacement?? TIA |
