Home > Technical > suspension connection
Thought you could only get amk these day? Dunno
Hitachi being the early ones
And Dunlop
Post #601371 Mon Jul 06 2020 6:42pm
Simonhunt72
United Kingdom 2006 Range Rover Sport Supercharged Bonatti Grey
Have heard Dunlop are poor?! Bearmach do amk I think for about 286 ,
Post #601372 Mon Jul 06 2020 6:43pm
Simonhunt72
So... New aerosus compressor in today, relay replaced, sits there doing nothing, what am I missing, all connected etc ,heeelp 🀣
Post #601586 Sat Jul 11 2020 6:16pm
Rossk3107
Scotland 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Still no codes? Shocked There is a control block just left of the compressor you could check. Iid tool should be your best friend at the moment πŸ‘πŸ» Present : 2007 RRS 3.6 TDV8
Present : Merc A class AMG
Previous : 2015 Evoque Black edition
Audi A6 3.0 TDI
Audi Q7 3.0 TDI
RRS 2.7 TDV6
BMW X5 3.0
Post #601606 Sun Jul 12 2020 7:13am
Simonhunt72
Hi, not checked for codes , just swapped out compressor and relay, am now getting red roll light and yellow roll light, cant get reader til tomorrow. Was under the impression it was just a swap,as compressor would not get up to pressure and overheat, no leaks tho
Post #601610 Sun Jul 12 2020 9:31am
Simonhunt72
So.. new compressor fitted,correct bracket finally😁 , still got issues with raising lowering etc, do I need to get the eas unit reset to accept new part, any advice greatly appreciated as always πŸ˜€
Post #601881 Fri Jul 17 2020 12:19pm
Simonhunt72
Update, so after compressor etc , it appears the accelerometer ( only land-rover) has the fault, but unsure of which one, I know the position of one under driver seat ,but believe there is another , any idea guys? Thanks in advance
Post #601959 Sun Jul 19 2020 6:18pm
Simonhunt72
Update, so found the second, behind interior light cluster, so which one ,would anyone know, controls forward back motion as in accelerate hard ,nose rises
Post #602502 Thu Jul 30 2020 1:48pm
Simonhunt72
Hi all , so had a reader connected, had c1b14 code , replaced lower accelerometer, still same fault and will not clear , also still have amber / red alternating . Have been now told to check voltage to sensor , any one got any guidance on this , been a bit quiet on response πŸ€”πŸ€£, yeh I know its a head scratcher, will be finding a large brick wall soon
Post #602872 Thu Aug 06 2020 5:14pm
Simonhunt72
So ,yeovil land rover 3 times ,each time made the fault worse , and left car in off road height, hundreds of pounds later and still no nearer to fault fix , accelerometer, ecu all replaced on their guidance ,still nothing, any help out there, as their techs are no help
Post #603904 Sat Aug 29 2020 4:24pm
