Home > Technical > suspension connection
Simonhunt72
Hi all ,rrs 2006 ,has had the lean light on, now wont adjust height, have been told to check connections as no fault on reader , where should I start ?? Passenger foot well has had water from good old sunroof drain, cheers all in advance
Post #599979 Tue Jun 09 2020 9:59pm
Simonhunt72
Update, now getting unable to adjust height randomly, and sometimes red warning, any help guys would appreciate it
Post #600919 Sat Jun 27 2020 9:53pm
Suspension module is above the driver's foot well, can be easily accessed by removing the panel immediately above the pedals.
It might be the exhaust valve in the compressor. This is not a serviceable item - a new compressor is required.
Otherwise, on the 4x4 info screen, are there any red lines above/below a wheel? 2012 SDV6 - it's missing a couple of cylinders
Post #600920 Sat Jun 27 2020 10:05pm
Simonhunt72
Hi, thanks for the reply, no red lines on display, would it be good to check the connections?
Post #600922 Sat Jun 27 2020 10:40pm
Do you have a fluid bottle by the air filter box ?
What engine
Post #600925 Sun Jun 28 2020 6:48am
Simonhunt72
A 2006 4.2 supercharger, yes i believe there is and I did check that a while ago
Post #600932 Sun Jun 28 2020 9:19am
The ACE system can trigger a red light. So you may want to read the ACE ecu to see if that has codes / clues
though if you can adjust the height, you were probably correct first time Embarassed
Post #600934 Sun Jun 28 2020 9:54am
Simonhunt72
Had a reader on it recently ,lots of ghost codes!!! But nothing to state an issue! And was unable to clear yellow lean light, it does seem to be random!!! But light has not gone off for a while now , and normal height only is more frequent. So may i ask what would be in passenger foot well , where it all got soaked
Post #600941 Sun Jun 28 2020 11:54am
I guess the wiring from the switches goes via the passenger footwell
most of the suspension wiring is run outside the car
Post #600943 Sun Jun 28 2020 12:15pm
Simonhunt72
Well sounds like the place to start , will keep posting updates ,thank you for your help andyk
Post #600944 Sun Jun 28 2020 12:26pm
Simonhunt72
So ,update, came out in the week to find rrs on its knees , back still up, will not raise the front , checked for leaks on back valve block ,nothing , compressor runs for a short time and is very noisy! Would it be a good shout to check the front block or bite the bullet and replace the compressor, as a good search through other feeds points to this being the probable fault, any help greatly received as always ,tia
Post #601281 Sat Jul 04 2020 4:22pm
Sounds like the compressor needs a service.
If it’s still noisy on the bench replace.
I would replace the seals in the front valve block
And then go fowards from there to see if anything else
Post #601284 Sat Jul 04 2020 5:20pm
Simonhunt72
Thank you Andy, got the darn thing raised, compressor still runs after good minute or so in off road , also had raising slowly, and will raise when system cooled . Found a receipt for Feb 2019 ,so called new amk unit fitted
Post #601287 Sat Jul 04 2020 5:25pm
Simonhunt72
So its been raised all night , not dropped one bit , hopefully pointing to no leaks , think replace compressor
Post #601324 Sun Jul 05 2020 11:11am
Simonhunt72
So ,chatted with garage today, confirmed the compressor runs too long and is noisy!! Receipt i have says AMK ,and fitted Feb 2019, what would you guys recommend as a good replacement?? TIA
Post #601370 Mon Jul 06 2020 6:17pm
