![]() | Home > Technical > suspension connection |
Thought you could only get amk these day? Dunno
Simonhunt72 Member Since: 13 Jan 2019 Location: Somerset Posts: 68 ![]() ![]() ![]() |
Have heard Dunlop are poor?! Bearmach do amk I think for about 286 , |
Rossk3107 Member Since: 22 Sep 2013 Location: Glasgow Posts: 32 ![]() ![]() ![]() |
Still no codes? |
Hi, not checked for codes , just swapped out compressor and relay, am now getting red roll light and yellow roll light, cant get reader til tomorrow. Was under the impression it was just a swap,as compressor would not get up to pressure and overheat, no leaks tho |
So.. new compressor fitted,correct bracket finallyπ , still got issues with raising lowering etc, do I need to get the eas unit reset to accept new part, any advice greatly appreciated as always π |
Update, so after compressor etc , it appears the accelerometer ( only land-rover) has the fault, but unsure of which one, I know the position of one under driver seat ,but believe there is another , any idea guys? Thanks in advance |
Update, so found the second, behind interior light cluster, so which one ,would anyone know, controls forward back motion as in accelerate hard ,nose rises |
Hi all , so had a reader connected, had c1b14 code , replaced lower accelerometer, still same fault and will not clear , also still have amber / red alternating . Have been now told to check voltage to sensor , any one got any guidance on this , been a bit quiet on response π€π€£, yeh I know its a head scratcher, will be finding a large brick wall soon |
So ,yeovil land rover 3 times ,each time made the fault worse , and left car in off road height, hundreds of pounds later and still no nearer to fault fix , accelerometer, ecu all replaced on their guidance ,still nothing, any help out there, as their techs are no help |
