Home > Technical > TV Screen not working
John1311
For some reason the centre screen in my my2013 RRS isn't working - I can turn the radio on and it works and get the display in the dash - but the screen is off. Going into reverse doesn't turn the monitor on either for rear view camera - just turned car on today and it didn't work - any ideas ? 2016 Range Rover Sport SDV6 autobiography (MY17)
2017 Range Rover Velar First Edition SDV6
2015 Range Rover Sport Autobiography 4.4
2012 Range Rover Sport SDV6 HSE Luxury Black
Post #599251 Mon May 25 2020 2:01am
If you get music from speakers, sounds like internal display fault
Post #599252 Mon May 25 2020 5:50am
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
Might be able to help here as mine has done the same a few times. Was the car sat in bright sun? Mine occasionally had the screen overheat last summer. Worked again once cooled. There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #599275 Mon May 25 2020 4:18pm
John1311
Quite possibly, has it worked fine the following day - how did you resolve that - or did you not in heat ? 2016 Range Rover Sport SDV6 autobiography (MY17)
Post #599322 Tue May 26 2020 8:41pm
Silverstone
Not resolved just know that if the car gets very hot the screen might not work. Took it back to the supplying garage and they read codes. Overheating display came up in codes. Might try leaving a duster on screen to keep direct sunlight off of it this summer. There is no replacement for displacement - W O Bentley
Post #599324 Tue May 26 2020 9:16pm
