Home > Technical > TV Screen not working |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
If you get music from speakers, sounds like internal display fault |
Mon May 25 2020 5:50am |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 |
Might be able to help here as mine has done the same a few times. Was the car sat in bright sun? Mine occasionally had the screen overheat last summer. Worked again once cooled. There is no replacement for displacement - W O Bentley
Mon May 25 2020 4:18pm |
John1311 Member Since: 05 Jul 2012 Location: Devon Posts: 40 |
Quite possibly, has it worked fine the following day - how did you resolve that - or did you not in heat ? 2016 Range Rover Sport SDV6 autobiography (MY17)
Tue May 26 2020 8:41pm |
Not resolved just know that if the car gets very hot the screen might not work. Took it back to the supplying garage and they read codes. Overheating display came up in codes. Might try leaving a duster on screen to keep direct sunlight off of it this summer. There is no replacement for displacement - W O Bentley
Tue May 26 2020 9:16pm |
