Home > Faults & Fixes > Suspension Fault RRS TDV8 2007
tricey27
Hi All.
When i turn car into a corner with a slight bit of haste I get a flashing red suspension light. With the note, suspension fault, please stop vehicle when safe to do so.
Any one have any ideas what this could be?
Suspension all functions as it should etc. Car is 2007 RRS 3.6 TDV8.
Many thanks in advance.
Post #598512 Mon May 04 2020 9:03am
PC76
I would check your fluid levels for the active damper.
it's the yellow cap just to the left of centre when you open the bonnet. It's prob just abovre the lower limit hence when cornering it triggers the fault.
I would then look for where it's leaking from..
Post #598531 Mon May 04 2020 2:44pm
Use the correct oil to top it up if it requires topping up. Expensive things live in that system and you don't want to give them any excuses to mess about further. 2012 SDV6 - it's missing a couple of cylinders
Post #598539 Mon May 04 2020 5:17pm
tricey27
Thanks for fast response guys. Just got home and checked and it’s a fair amount below the min mark. So going to get it topped up. Wondering if the cap is poor as the top of reservoir is wet.
What fluid do I need to top this up? Or is it just the LR Cold Climate fluid?
Thanks
Post #598542 Mon May 04 2020 6:07pm
Yes, LR Cold Climate PAS fluid. 2012 SDV6 - it's missing a couple of cylinders
Post #598548 Mon May 04 2020 7:22pm
tricey27
Thank you very much!
Topped the fluid up and hasn’t missed a beat! Will monitor level and see how it goes.
Thanks.
Post #598749 Sat May 09 2020 6:24pm
