Home > Faults & Fixes > Suspension Fault RRS TDV8 2007 |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
I would check your fluid levels for the active damper.
Mon May 04 2020 2:44pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Use the correct oil to top it up if it requires topping up. Expensive things live in that system and you don't want to give them any excuses to mess about further. 2012 SDV6 - it's missing a couple of cylinders
Mon May 04 2020 5:17pm |
tricey27 Member Since: 01 May 2020 Location: Yorkshire Posts: 10 |
Thanks for fast response guys. Just got home and checked and it’s a fair amount below the min mark. So going to get it topped up. Wondering if the cap is poor as the top of reservoir is wet.
Mon May 04 2020 6:07pm |
Yes, LR Cold Climate PAS fluid. 2012 SDV6 - it's missing a couple of cylinders
Mon May 04 2020 7:22pm |
Thank you very much!
Sat May 09 2020 6:24pm |
