Home > Maintenance & Modifications > ace pipe leak |
You have 4 pipes on the front right and 2 on the rear right.
Tue May 05 2020 7:56pm |
And this is what the pipe set looks like, different engined vehicles have different pipes so you would need the correct type. The ones here are for the 5.0 but malting list them all.
Tue May 05 2020 8:02pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Yeah, they are all a mess and need replacing. Kev
Tue May 05 2020 8:06pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
Right cheer Brit Plumber. I'll fix them first then after that I can track the other oil leak down |
Tue May 05 2020 8:21pm |
right pipes ordered. front and back. speaking to the dude he said i dont need to lift the body and he'll send fitting instructions.
Fri May 08 2020 8:24am |
It's great news that you're making progress with this. I hope you got your pipes for the lower price!
Fri May 08 2020 9:22am |
i didn't but thankfully this is my company car, so ill be able to claim back the VAT |
Fri May 08 2020 9:42am |
quick question Brit Plumber if am buying the couplings, these that you linked to in another post,
Fri May 08 2020 10:44pm |
Apologies, I noticed a typo in my previous post. You need a 38mm socket for the valve block.
Sat May 09 2020 8:38am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
If your profile is correct, and its an 06 car, the outrigger will unbolt from the chassis, so you won't have to lift the body at all |
Sat May 09 2020 8:44am |
I think it was the 10mm but I bought mine from a local agricultural and machinery specialist. If I remember correctly, I was pleasantly surprised by the price and got Stainless for something like an extra 20p each and rated to 10 times that of the ACE system. Hopefully you want need them and you can unbolt the out rigger as DM said. To remove the pipes from the valve block I used a tool like this https://www.ebay.co.uk/itm/US-Pro-Plastic-...Swj0NUbyln I put the open end over the flared part of the pipe and levered them out. I believe they can be a nightmare but mine popped out in short order (the car was 7 year old so older could be more difficult). 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Sat May 09 2020 9:07am |
id rather raise the body tbh if i can. but the seller seems to think I wouldnt need to. we'll see either way.
Sat May 09 2020 8:17pm |
I don’t think removing the one bolt will make any difference, there’s 4 or 5? On each side.
Sat May 09 2020 10:38pm |
anyone used stuff like ACF50 to try and keep the pipes in good nick? |
Sun May 10 2020 9:26am |
