Home > Maintenance & Modifications > Going rate for a timing belt change on '12 RRS (SE England)?
Page 3 of 3 <123
Tingle
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bourneville
@knwatkins2
Thank you for the reply I shall have a look and see if I can spot a sticker.
Cheers,
Tingle.
Post #600182 Sat Jun 13 2020 11:34am
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
My local indy (who i've only used once before) tells me the waterpump is normally done at the same time which made sense but another one says its not normally done as its not driven by the timing belt.
Anyone here know?
Cheers,
Pete. L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #600356 Wed Jun 17 2020 7:59am
knwatkins
It's not driven by the timing belt, it's driven by the auxiliary belt.
It's up to you if you want to change it. They are about £75. Kev
Post #600359 Wed Jun 17 2020 8:19am
abiopete
Cheers Kev, is it worth doing, are they prone to failure?
Post #600362 Wed Jun 17 2020 9:46am
knwatkins
Personally, I wouldn't. I'd just replace it if its noisy. It's one of those things though, some people replace them because it makes them feel better.
The way I think of it is that there are many other things that could potentially fail on the vehicle that would result in a nightmare situation so why single out the waterpump? What about the oil pump, turbos, hoses, brake servo, vacuum pump etc.?
If it was that critical to be replaced at a certain interval, it would be on the service schedule along with the belts.
That's just my two penneth. I'm sure other people will have different views. Kev
Post #600364 Wed Jun 17 2020 10:13am
abiopete
Reasonable way of looking at it, i think i'll adopt the same stance! Thumbs Up
Post #600365 Wed Jun 17 2020 10:21am
Phil2k
Just had a quote for my 2012 today and it was £630 from my local indy
Post #600665 Mon Jun 22 2020 9:19pm
Page 3 of 3 <123
