Home > Technical > Speedo needle lighting
Buckster
Does anyone know what’s involved in fixing the lighting on the speedo needle, it’s currently intermittently flickering on and off Rolling Eyes 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #596459 Fri Mar 13 2020 8:44pm
Disco_Mikey
Officially, a new IPC
Not sure if they can be repaired, beyond my pay grade Laughing
Post #596463 Fri Mar 13 2020 9:36pm
Godders
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Ive got the same problem on mine and watching with interest Shocked Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #596467 Fri Mar 13 2020 10:43pm
gogsy1956
Appears to e a common fault,, not something for the average Diy buff to attempt. There are a few places that repair faulty instrument
Clusters,,,, one being an outfit called totaltronics. Check out their website for more info but basically you an post your cluster to them for repair in a one or two day turnaround,,, or if your local they will remove the cluster as well. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #596481 Sat Mar 14 2020 2:39pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I had my cluster replaced by RR, common fault. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #596488 Sat Mar 14 2020 6:50pm
Robs_2007_sport_hse
Take the instrument cluster out and post it to these guys there fantastic
http://www.bba-reman.com/gb/index.aspx
Post #596509 Sun Mar 15 2020 7:59am
Buckster
Now my reversing camera has decided it wants to work intermittently and takes the front and rear parking sensors out when it decides to turn itself off Big Cry 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #596534 Sun Mar 15 2020 4:21pm
Buckster
New instrument cluster fitted so normal service has now resumed Rolling Eyes 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #598707 Fri May 08 2020 1:56pm
Wenier
New Zealand 2010 Range Rover Sport TDV8 HSE Santorini Black
If your good with soldering it is just surface mount LEDs on the circuit board failing. They are normally in pairs.
Remove, disassemble, figure out what LED you need and replace.
Obviously time between getting LED means you are parked up not going anywhere. 2010 RRS TDV8 181000km
2005 D3 TDV6 307000km
Post #598819 Tue May 12 2020 7:23am
