Home > Technical > Speedo needle lighting |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4394 |
Officially, a new IPC
Fri Mar 13 2020 9:36pm |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 |
Ive got the same problem on mine and watching with interest Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Fri Mar 13 2020 10:43pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Appears to e a common fault,, not something for the average Diy buff to attempt. There are a few places that repair faulty instrument
Sat Mar 14 2020 2:39pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 200 |
I had my cluster replaced by RR, common fault. 2018 Telsa MS
Sat Mar 14 2020 6:50pm |
Robs_2007_sport_hse Member Since: 12 Mar 2020 Location: Devon Posts: 5 |
Take the instrument cluster out and post it to these guys there fantastic
Sun Mar 15 2020 7:59am |
Now my reversing camera has decided it wants to work intermittently and takes the front and rear parking sensors out when it decides to turn itself off 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Mar 15 2020 4:21pm |
New instrument cluster fitted so normal service has now resumed 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Fri May 08 2020 1:56pm |
Wenier Member Since: 09 Apr 2019 Location: Christchurch Posts: 15 |
If your good with soldering it is just surface mount LEDs on the circuit board failing. They are normally in pairs.
Tue May 12 2020 7:23am |
