Home > Technical > ACC and cruise control problem
Sticky
Hi All
I have just bought a 2008 RRS TDV8. While driving it home I noticed that the cruise control was "UNAVAILABLE". The previous owner has upgraded the front bumper to one with a lower spoiler. In doing so he has removed the ACC module and not replaced it as there is not an aperture for it. Is this the reason the cruise is unavailable and is it a big job refitting a second hand one off ebay. Will this get the cruise control back?
Cheers Pete
Post #595777 Sat Feb 29 2020 10:05am
Yes, if the ACC sensor is removed then the cruise control won't work. You can either put the sensor back on - and get it set to point correctly - or you can use an IID Tool (or similar) to alter the CCF to set it to standard cruise control. Then you'll have non-ACC cruise control available.
What bumper cover did he fit? Any pictures? 2012 SDV6 - it's missing a couple of cylinders
Post #595780 Sat Feb 29 2020 10:29am
Sticky
Fantastic, you could be a life saver here. Where can I get IID tool??? and is it easy to fit. Im not botherred about the ACC, from what Ive heard its a nuisance.
Cheers Pete
photo attached
Post #595781 Sat Feb 29 2020 10:36am
Sticky
Its ok, found it. Its the tool used by a garage to access the ecu to make changes. I will ask my mechanic if he can do it?
Thanks
Post #595782 Sat Feb 29 2020 10:44am
Eaters
Some swear by the IID and its certainly hovering in the back of my mind to get one. But I haven't yet - after 4 years RRS ownership. I've maybe been fortunate in that my local indie is good and for reasonable cost I can leave them to sort it out when necessary. I guess another aspect is that on a gravel drive it is not much fun jacking up the car or searching for dropped nuts and bolts. Perhaps on a tarmac drive with a large garage or workshop as well, things might be different.
And as with all things its a matter of preference. I like the ACC and find it very useful on long journeys. But its horses for courses. Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #595785 Sat Feb 29 2020 11:52am
Cheers Pete
I'm a fan of ACC and miss it. My TDV8 had it but my SDV6 doesn't. If you do good periods on motorways, ACC is an excellent tool. Not much use on ordinary roads. 2012 SDV6 - it's missing a couple of cylinders
Post #595812 Sat Feb 29 2020 7:29pm
Sticky
Hi, well, apparantly it doesn't seem that easy. Its been in to a local Land Rover specialist, Discovery Centre near Harrogate and they have tried deleting the fact that it doesn't have an ACC sensor but to no avail. They can get cruise to work but it only lasts a few seconds and then switches off, never to appear again. Switch ignition off and restart and it works for a few seconds then switches off again. They have suggested getting a second hand ACC sensor (new £1200 so b*****er that) and they will tape it to the front and see if it makes a difference.
Post #596405 Thu Mar 12 2020 11:59am
scrumps
Hi,
Two sensors on an auction site near you @ £150
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #596541 Sun Mar 15 2020 7:58pm
Sticky
Thanks, yes Ive got one now but there is no place for it on the bumper I have. Although it has a plastic cover the aperture on the dedicated bumper has a plastic cover, presumably to protect from stones. So may need to change the bumper back to standard, so more £££££ to buy one, repair it and spray it Java black.
Post #596554 Mon Mar 16 2020 8:16am
