Home > Faults & Fixes > C1A13 pressure won’t exhaust
Quad555
England 2012 Range Rover Sport SDV6 Autobiography Orkney Grey
Had a suspension problem with my 2012 autobiography, new pump was fitted in august 2019. All was good until I went to lower suspension to get the dogs in, it Bounced back up to extended height. Did this every time, if I tried to raise it ,”orange light and suspension fault.” Plugged in sdd, read code c1a13 pressure won’t exhaust in gallery.
Didn’t think it would be the new pump, so started the normal checks. Two rear sensors, front and rear solenoid valves and reservoir valve later, and still the same.
Lots of head scratching later, took off the new AMK pump, stripped out the solenoid valve ,two torx screws and a plug. (thought this seems a bit tight in here) .Cleaned, lubricated and refitted , bingo! works a treat.
hard fault to trace as you don’t expect a new part to be defective??
Any way, easy fix just a bit of time and a little bit of grease! Thumbs Up
Post #595356 Sat Feb 22 2020 3:46am
Eaters
Nice fix. Good to know. Also that we shouldn't necessarily trust a new part to be perfect Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #595359 Sat Feb 22 2020 7:51am
Was it a genuine AMK or Chinese AMK?
Post #595363 Sat Feb 22 2020 8:32am
Quad555
Genuine,AMK. checked and tested by Lauren in the factory. (As it says on the build label )
Post #595364 Sat Feb 22 2020 8:40am
