Home > Technical > Parking sensor issue
Wayneclarke
Does anyone have any ideas as to why I'm getting these fault codes?
Post #591960 Tue Dec 17 2019 1:13pm
one of the 8 sensors has failed shorted
or a short on the wiring loom behind a bumper
sorry that doesn't narrow it down much !
If you have a fault code reader yourself, I would unplug the front loom below the drivers headlight.
leave it disconnected.
clear faults.
start car and put in reverse
release park brake
listen to see if beeps have changed
rescan fault codes and see if the top 2 are still there or not.
If its gone, fault at the front
if its still there, fault at the rear.
obviously it will complain about the 4 front sensors being disconnected
Post #591973 Tue Dec 17 2019 5:49pm
Wayneclarke
Cheers Andy for the reply, I dont have a scanner but will pass this info onto the garage see what they say. After they cleared the faults it worked fine for hours but then just went again.
Post #591975 Tue Dec 17 2019 5:54pm
