Home > Technical > Battery drain
G carrington
Guernsey 2006 Range Rover Sport TDV6 HSE Santorini Black
Battery drain
Hi I have just joined this forum and I hope I’m on the right page lol not good with computers
I have a rr sport with a few problems I have sorted most of them but now I’m stuck
I have a 4.6 A continuous drain on my battery so it’s flat overnight
I have put a meter on the battery and pulled all he fuses under the bonnet with no change
So tried all the fuses behind the glove box and sill no change
Does anyone know if there are any other fuse boxes anywhere or infused supply’s going to anywhere
By the way I disconnected the supply to engine to rule out alternator
Any help would be greatly appreciated
Post #591900 Sun Dec 15 2019 2:17pm
I would recheck the big J fuses under the bonnet.
Post #591902 Sun Dec 15 2019 5:28pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
hello there
pull relays as well, does fusebox smell burnt?
does it go to sleep, if, is drain same?
my first guess would be alternator but you said it was disconnected sure?
Post #591907 Sun Dec 15 2019 8:17pm
G carrington
Well I think the alternator is disconnected
I took the wire off the battery that runs to the engine and there was no fault on that
I have pulled all fuses under the bonnet
But I haven’t pulled the relays as I thought they would be supplied by the fuses anyway
Post #591933 Mon Dec 16 2019 7:49pm
Oldandconfused
https://www.disco3.co.uk/forum/robbies-gui...19574.html
Worth a look?
Post #591950 Tue Dec 17 2019 10:49am
this is worth looking at too.
I would recommend you measure the current in the big J fuses as most things should be powered through them.
When you find which one it is, you can dig further
https://www.disco3.co.uk/forum/heelllllp-b...4-105.html
Post #591976 Tue Dec 17 2019 6:09pm
G carrington
Hi Andy I have pulled out all the j fuses and there was still the same drain 4.6amps
I pulled back the top of the fuse box and it looks like there are some wires coming from the permanent live side of the rail which drop into the fuse box and are spliced with a few more
The clamp meter that I have only does ac amps so have ordered another one
As soon as I get it I will try clamping these cables and see where we go from there
Cheers for the help mate
Post #592009 Wed Dec 18 2019 10:48am
So if you have removed all the large J fuses under the bonnet, without a drop, and the thick cable to the engine.
try removing these one by one and see if it drops.
small fuses under bonnet.
No.
20 ALT
23 abs
26 AIR SUSPENSION
30 GEARBOX
28 FBH DIESEL MODELS
27 ENGINE ECU
Post #592031 Wed Dec 18 2019 7:17pm
Clive.240
Did you sort out your battery drain issue I am having similar problems just got a clamp meter so will start investigating this weekend
Post #608230 Wed Jan 06 2021 11:21pm
Unfortunately people come on to the forum and ask questions about a issue or fault, are given suggestion as to the problem by members then appear to be reluctant or cannot be bothered to come back to say if they have resolved the issue or not, which may also help others members, until they have another problem and do exactly the same.
I do believe the rear upper tailgate switch/heated screen is quite a common problem causing battery drain on the pre-facelift RRS1 so might be worth checking that.
Post #608232 Thu Jan 07 2021 1:56am
riverblanche
Hi,
sadly its as Col says Sad
oldandconfused gave a link to Robbies guide which is an excellent walk through guide and worth following Thumbs Up
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #608247 Thu Jan 07 2021 12:43pm
Guyzer73
Hi Col,
I have the same battery drain problem... If I pull Fuse 13 passenger to disconnect the heated rear screen, will this also disable the upper tailgate switch or is this separate? I can't find a suitable fuse for it.
Post #616291 Mon Aug 02 2021 10:58am
I don't think it has a separate fuse of its own - it's part of the overall locks and latches etc. The simplest thing might be to just disconnect the switch and see if the drain disappears or not. 2012 SDV6 - it's missing a couple of cylinders
Post #616293 Mon Aug 02 2021 11:25am
Guyzer73
Cheers RRSTDV8,
I'll pull the fuse for the rear heated screen and pull the plug on the switch and see what happens. Will also look to check the Alternator, but thats a fairly new replacement anyway...
Thanks again, let you know how it goes
Post #616295 Mon Aug 02 2021 11:53am
Pull the switch plug on its own, of course, not at the same time as the fuse. That way you know which is the issue. 2012 SDV6 - it's missing a couple of cylinders
Post #616297 Mon Aug 02 2021 1:02pm
