![]() | Home > Technical > Battery drain |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
I would recheck the big J fuses under the bonnet. |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
hello there
G carrington Member Since: 15 Dec 2019 Location: Channel islands Posts: 5 ![]() ![]() ![]() |
Well I think the alternator is disconnected
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
https://www.disco3.co.uk/forum/robbies-gui...19574.html
this is worth looking at too.
Hi Andy I have pulled out all the j fuses and there was still the same drain 4.6amps
So if you have removed all the large J fuses under the bonnet, without a drop, and the thick cable to the engine.
Clive.240 Member Since: 10 Dec 2018 Location: Mid-Wales Posts: 4 ![]() ![]() ![]() |
Did you sort out your battery drain issue I am having similar problems just got a clamp meter so will start investigating this weekend |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Unfortunately people come on to the forum and ask questions about a issue or fault, are given suggestion as to the problem by members then appear to be reluctant or cannot be bothered to come back to say if they have resolved the issue or not, which may also help others members, until they have another problem and do exactly the same.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Hi Col, I have the same battery drain problem... If I pull Fuse 13 passenger to disconnect the heated rear screen, will this also disable the upper tailgate switch or is this separate? I can't find a suitable fuse for it. Cheers Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
I don't think it has a separate fuse of its own - it's part of the overall locks and latches etc. The simplest thing might be to just disconnect the switch and see if the drain disappears or not. 2012 SDV6 - it's missing a couple of cylinders
Cheers RRSTDV8,
Pull the switch plug on its own, of course, not at the same time as the fuse. That way you know which is the issue. 2012 SDV6 - it's missing a couple of cylinders
