Home > In Car Electronics > Loss of DAB
wilf
Loss of DAB
My good friends "down south" have an issue with their 2011 3.0 TDV6 HSE in that AM/FM is fine, but DAB is not available. Screen just says "no reception", and won't tune.
They have been quoted £1000 to fix it, having taken it to an Indy near Brighton. (not sure who).
Any thoughts from the collective? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #591179 Fri Nov 29 2019 10:41am
aaronjb
Following, because mine has a habit of doing the same thing - I mean, the reception is shocking generally (compared to newer cars), but sometimes will just sit and do nothing at all for a bit after starting.
Also .. wilf, on the naughty step - the same wilf who used to own a Crendon, by any chance? If so, it's a small bloody world, this Internet thing. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #591184 Fri Nov 29 2019 12:08pm
wilf
Um, might be, lol.
Crendon now in another home, doing zero miles pa between MOTs, sadly. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #591187 Fri Nov 29 2019 1:28pm
aaronjb
Sad indeed! I remember your departure to the land of .. Stag, was it? Still haven't finished mine.. Anyhow.. back to DAB! Smile 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #591193 Fri Nov 29 2019 2:35pm
Oldandconfused
Coincidentally, The DAB in mine was playing up a few days ago, crackling a bit. It now seems OK all on it's own. That being said, it's not a patch on my last car a 2016 Civic.
Post #591200 Fri Nov 29 2019 4:07pm
wilf
OK, so no-one can help, but can anyone tell me if the DAB module is indeed a separate module, and where is it located? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #591677 Mon Dec 09 2019 8:08pm
Not the best shot but item 13 by the looks of it, could be worth checking the aerials first which are items 9 and 20.
Post #591682 Mon Dec 09 2019 9:08pm
Autobiography1969
Wilf
The reception in general darn Sarf is pretty bad generally,
mine crackles and sometimes goes dead for a few moments,
but never lost signal for more than a few shortish period of time.
The TV as well is very poor, its only really when I go away on hols
that it all works as it should..
would be great if there was an easy fix that doesn't cost the earth, ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #591693 Mon Dec 09 2019 10:11pm
wilf
Thanks both. The issue here is that it was working, then stopped, so something has failed somewhere. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #591707 Tue Dec 10 2019 8:26am
Brit Plumber
Col has indicated the correct module. Can you confirm it’s DAB+ and not just DAB?
Many stations are moving from DAB to DAB+ so it may be that there’s no signal displayed because there is no signal.
If there is a fault, there should be a DTC for it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #591749 Wed Dec 11 2019 8:44am
wilf
Can't provide any more info, sorry. Issue is that my friends, whose car this is, are not really technical. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #591765 Wed Dec 11 2019 4:12pm
Brit Plumber
Ask them if they can get any reception. It may be that the station they regularly listen to has moved to DAB+, I’ve a feeling that it was MY12 that introduced the + so if there’s is a 2011 registered 11MY, that could be their issue. There is a retro kit available but I wouldn’t recommend it unless they can confirm if it’s a complete loss or just their go to Station moving over. 2019 5.0 SC SVA (Current)
Post #591773 Wed Dec 11 2019 5:56pm
wilf
I did do that, they can still get FM/AM, but nada on DAB, not single station will tune in. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #591784 Wed Dec 11 2019 8:52pm
