![]() | Home > In Car Electronics > Loss of DAB |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Following, because mine has a habit of doing the same thing - I mean, the reception is shocking generally (compared to newer cars), but sometimes will just sit and do nothing at all for a bit after starting.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Um, might be, lol.
Sad indeed! I remember your departure to the land of .. Stag, was it? Still haven't finished mine.. Anyhow.. back to DAB! |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Coincidentally, The DAB in mine was playing up a few days ago, crackling a bit. It now seems OK all on it's own. That being said, it's not a patch on my last car a 2016 Civic. |
OK, so no-one can help, but can anyone tell me if the DAB module is indeed a separate module, and where is it located? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Not the best shot but item 13 by the looks of it, could be worth checking the aerials first which are items 9 and 20.
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
Wilf
Thanks both. The issue here is that it was working, then stopped, so something has failed somewhere. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Col has indicated the correct module. Can you confirm it’s DAB+ and not just DAB?
Can't provide any more info, sorry. Issue is that my friends, whose car this is, are not really technical. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Ask them if they can get any reception. It may be that the station they regularly listen to has moved to DAB+, I’ve a feeling that it was MY12 that introduced the + so if there’s is a 2011 registered 11MY, that could be their issue. There is a retro kit available but I wouldn’t recommend it unless they can confirm if it’s a complete loss or just their go to Station moving over. 2019 5.0 SC SVA (Current)
I did do that, they can still get FM/AM, but nada on DAB, not single station will tune in. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
