Home > In Car Electronics > Loss of DAB |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Following, because mine has a habit of doing the same thing - I mean, the reception is shocking generally (compared to newer cars), but sometimes will just sit and do nothing at all for a bit after starting.
Fri Nov 29 2019 12:08pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Um, might be, lol.
Fri Nov 29 2019 1:28pm |
Sad indeed! I remember your departure to the land of .. Stag, was it? Still haven't finished mine.. Anyhow.. back to DAB! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Fri Nov 29 2019 2:35pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Coincidentally, The DAB in mine was playing up a few days ago, crackling a bit. It now seems OK all on it's own. That being said, it's not a patch on my last car a 2016 Civic. |
Fri Nov 29 2019 4:07pm |
OK, so no-one can help, but can anyone tell me if the DAB module is indeed a separate module, and where is it located? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Mon Dec 09 2019 8:08pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Not the best shot but item 13 by the looks of it, could be worth checking the aerials first which are items 9 and 20.
Mon Dec 09 2019 9:08pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 470 |
Wilf
Mon Dec 09 2019 10:11pm |
Thanks both. The issue here is that it was working, then stopped, so something has failed somewhere. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Tue Dec 10 2019 8:26am |
Col has indicated the correct module. Can you confirm it’s DAB+ and not just DAB?
Wed Dec 11 2019 8:44am |
Can't provide any more info, sorry. Issue is that my friends, whose car this is, are not really technical. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Wed Dec 11 2019 4:12pm |
Ask them if they can get any reception. It may be that the station they regularly listen to has moved to DAB+, I’ve a feeling that it was MY12 that introduced the + so if there’s is a 2011 registered 11MY, that could be their issue. There is a retro kit available but I wouldn’t recommend it unless they can confirm if it’s a complete loss or just their go to Station moving over. 2019 5.0 SC SVA (Current)
Wed Dec 11 2019 5:56pm |
I did do that, they can still get FM/AM, but nada on DAB, not single station will tune in. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Wed Dec 11 2019 8:52pm |
