Home > General > DRL when lights on Auto
idi
I have a 2010 RRS with the standard headlights:
http://www.enkahnz.co.uk/wp-content/upload...HTS-UK.jpg
However the LED lights that are lit up in the picture only turn on when I set the lights to position 1, like normal sidelights. Is there any way they can always be on when the lights are in Auto mode?
Post #590609 Tue Nov 19 2019 12:52pm
knwatkins
It's easy enough to do with a mod to the wiring in the internal fusebox. See my posts in this thread...
https://www.rrsport.co.uk/forum/topic53036-15.html Kev
Post #590615 Tue Nov 19 2019 3:06pm
idi
Can you just clarify what that actually does? Have you just connected some wires together that run a constant +ve to the lights when the ignition is on?
Post #590618 Tue Nov 19 2019 3:37pm
knwatkins
It's not whilst the ignition is on, it's whilst the car is awake (ie. when it's unlocked). But yes, that's the principle. Kev
Post #590620 Tue Nov 19 2019 4:33pm
idi
Great. Doesn't look too hard so I'll give it a go. Do the lights turn on when unlocking the car using the key?
Post #590621 Tue Nov 19 2019 4:51pm
knwatkins
Certainly does Wink Kev
Post #590622 Tue Nov 19 2019 5:20pm
idi
Sorry, Last question.
If I didn't add the switch, is it just a simple case of changing 4 fuses to ones with breakout wires, and connecting fuse 49 wire to Fuse 24 wire and Fuse 50 wire to Fuse 25 wire?
Post #590624 Tue Nov 19 2019 5:27pm
knwatkins
That's correct. I did this initially then added the switch later. Kev
Post #590627 Tue Nov 19 2019 5:44pm
jason-nike
This mod works great, nice touch also is that LEDs come on when you unlock the car as well as always being on when car is "alive".
It would be great if we were able to fit brighter LEDs as current ones are not as bright as I would like
Post #590659 Tue Nov 19 2019 11:32pm
Brit Plumber
I’ve done this mod on my car. I’ve also modified the DRL to stay on with the sidelights so that both work together. When I originally carried out the mod, the DRLs wouldn’t work as the Land Rover instructions tell you to connect into the side light wire. I just changed that wire to the main light wire so now they go off with the main beam.
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #590667 Wed Nov 20 2019 10:17am
idi
I know I'm an idiot, but I still can't get my head around how this works.
Fuse 24 and 25 are for the rear lights? and fuse 49 and 50 are for the front DRL lights? So how can connecting the two together turn the lights on all the time?
Post #590747 Thu Nov 21 2019 3:44pm
Brit Plumber
Fuse 24 and 25 are side lights i.e. the fairy lights you want to use as DRLs (as well as the rear lights).
Fuse 49 and 50 is the adaptive front lighting.
So the adaptive front lights wiring (whether you have them installed or not) has power from unlocking the vehicle so this powers the LEDs all the time the vehicle is unlocked up to the point the BCM goes to sleep (after a few minutes). 2019 5.0 SC SVA (Current)
Post #590748 Thu Nov 21 2019 4:03pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
i don't know if the DRL's are different on a RRS to a FFRR, but the lights look the same! I used my IID tool to set the DRL's to one of the other settings Canadian/Scandinavian and that turns them on all the time also. Is this not possible on a RRS? seems much easier than messing about with wires. Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #590782 Fri Nov 22 2019 7:27am
You can activate them in the CCF files but has to be in conjunction with headlight/tailight configuration no facility to activate the fairylights on their own.
Post #590784 Fri Nov 22 2019 8:13am
Brit Plumber
There’s also a specific DRL CCF setting but I think this is just a standard EUC file and does nothing except give you 2 DTCs for them not working. 2019 5.0 SC SVA (Current)
Post #590785 Fri Nov 22 2019 8:43am
