Home > General > DRL when lights on Auto |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
I have a 2010 RRS with the standard headlights:
Tue Nov 19 2019 11:52am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
It's easy enough to do with a mod to the wiring in the internal fusebox. See my posts in this thread...
Tue Nov 19 2019 2:06pm |
It's not whilst the ignition is on, it's whilst the car is awake (ie. when it's unlocked). But yes, that's the principle. Kev
Tue Nov 19 2019 3:33pm |
Great. Doesn't look too hard so I'll give it a go. Do the lights turn on when unlocking the car using the key? |
Tue Nov 19 2019 3:51pm |
Certainly does Kev
Tue Nov 19 2019 4:20pm |
Sorry, Last question.
Tue Nov 19 2019 4:27pm |
That's correct. I did this initially then added the switch later. Kev
Tue Nov 19 2019 4:44pm |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
This mod works great, nice touch also is that LEDs come on when you unlock the car as well as always being on when car is "alive".
Tue Nov 19 2019 10:32pm |
I’ve done this mod on my car. I’ve also modified the DRL to stay on with the sidelights so that both work together. When I originally carried out the mod, the DRLs wouldn’t work as the Land Rover instructions tell you to connect into the side light wire. I just changed that wire to the main light wire so now they go off with the main beam.
Wed Nov 20 2019 9:17am |
I know I'm an idiot, but I still can't get my head around how this works.
Thu Nov 21 2019 2:44pm |
Fuse 24 and 25 are side lights i.e. the fairy lights you want to use as DRLs (as well as the rear lights).
Thu Nov 21 2019 3:03pm |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
i don't know if the DRL's are different on a RRS to a FFRR, but the lights look the same! I used my IID tool to set the DRL's to one of the other settings Canadian/Scandinavian and that turns them on all the time also. Is this not possible on a RRS? seems much easier than messing about with wires. Current: 2010 RRS 3.6 TDV8 HSE
Fri Nov 22 2019 6:27am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4992 |
You can activate them in the CCF files but has to be in conjunction with headlight/tailight configuration no facility to activate the fairylights on their own.
Fri Nov 22 2019 7:13am |
There’s also a specific DRL CCF setting but I think this is just a standard EUC file and does nothing except give you 2 DTCs for them not working. 2019 5.0 SC SVA (Current)
Fri Nov 22 2019 7:43am |
