Home > General > Side Step Trim Falling Off :( |
Xstyle Member Since: 14 Jul 2014 Location: Berkshire Posts: 46 |
Thank you! I presume OK for the 2010 L320 model too, as listed from 2013+?
Sun May 08 2022 7:12pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Just use Stainless Steel pop rivets won't corrode again, all side steps on the RRS1 are the same although the kit part number changed when they changed the plastic trims included in the kit from pre-cut ones to uncut ones to save a few pence.
Sun May 08 2022 11:20pm |
Do you HAVE to take off the side step first?
Mon May 09 2022 6:48am |
... and will this do the trick?
Mon May 09 2022 7:02am |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
you can do it underneath with the clamps
Mon May 09 2022 6:17pm |
I used 4.8mm head stainless steel rivets.
Fri May 13 2022 10:51pm |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 257 |
An old trick when using pop rivets is to put a washer on the other side to the rivet head so the expansion of the rivet grips the washer, not the base metal. This enlarges the clamping area, particularly useful if the original hole is in poor condition due to corrosion. Use a washer sized as close to the rivet as possible and of course make sure the rivet is long enough to clamp all 3 parts. RRS HSE Dynamic SDV6 2014
Tue May 17 2022 3:28pm |
Yeah, it fell off. Didn't go through at all.
Tue May 17 2022 4:34pm |
Extra long length rivet heads, up to 20mm.
Sat Jun 18 2022 2:16pm |
Shall I buy the 20mm head length?
Tue Jul 05 2022 5:04pm |
