Home > General (L494) > 2016 SVR Knocking Front Suspension Help Please
carlos50
Hi all
New to me 2016 SVR with 43k miles on the clock clunks over pot holes, joints in tarmac etc. dealer has inspected it and didn't see anything untoward but I can deffo still hear it. To avoid endless trips without success do you guys know what the likely cause is please? The SVR has the updated valve block I believe so assume its not that, when it happens it feels like lower control arms or roll bar bushes, the common ones, but if inspected and not seen to be worn don't want to pay to replace then still have the knocking.
If seems to improve a little when in Dynamic mode, the tighter /stiffer suspension helping reduce the knocking.
This particular one sat on the dealers forecourt for a fair few months so maybe just needs some time on the road but I'm assuming bushes somewhere?
Thanks
Carl
Post #589916 Tue Nov 05 2019 3:11pm
Tyrefitter
Mines not a svr but their is a slight dip in the road just round the corner where I live & every time I hit it with the passenger wheel it makes a knocking sound but I’ve had it up in the air & cannot find anything worn & mines on 56000miles. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #589927 Tue Nov 05 2019 6:19pm
RobF
My 2016 HSE Dynamic sounded like a bag of nails over every bump. I put it in the dealer saying it sounded like my old Disco4 when the ARB bushes failed.
And guess what? The ARB bushes had failed....replaced and perfect since.
Not saying it's the same thing here but worth a check
Post #589941 Tue Nov 05 2019 10:44pm
Tyrefitter
Mine only does at that dip in road,their is a few speed bumps in local supermarket & it doesn’t do it over those. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #589944 Wed Nov 06 2019 5:53am
wilf
Might be worth looking at your tyre pressures?
On my car, if I had the front pressures up a little, then "tyre slap" over road irregularities could sound like a knock. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #590003 Thu Nov 07 2019 7:57am
carlos50
Pressures are all perfect, knocking is much worse on broken country lane type surfaces, going to try new ARB bushes its a cheap fix so worth a go
Thanks
Post #590146 Sat Nov 09 2019 9:11am
carlos50
ARB bushes, changed today and silence
Simple fix for once
Post #590471 Fri Nov 15 2019 7:42pm
wilf
Good news.
Just a shame the Dealer didn't spot it. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #590477 Fri Nov 15 2019 8:51pm
