Home > Wheels & Tyres > L494 wheels on a L 320 problems
Page 2 of 3 <123>
knwatkins
I wouldn't worry about the CCF. All that would do would be to realign your speedo, it won't affect DSC and the issue you are experiencing.
Have you tried putting your old wheels back since the new ones were fitted? If not, that would be the next step. If you have dislodged an ABS sensor whilst changing wheels, as RRSTDV8 suggested, this would show up again with your old wheels. Kev
Post #589201 Thu Oct 24 2019 9:25pm
MEC
United Kingdom 2007 Range Rover Sport TDV6 HSE Sumatra Black
Yes have put old wheels back on car drives perfect so definitely seems to be related two new wheels having a larger rolling circumference just can't figure out why why when all for match do you have a wheel bearing on driver's side that has a little bit of playing it which is next on the list don't think that would affect it as it's it's fine with the old wheels on
Post #589203 Thu Oct 24 2019 10:18pm
1richard1
Hi did you have them balanced? or has one wheel got a buckle in it? I have put 22" wheels on while my 20" get refurbed no problem, or it may just be slightly thinner wheel and even whilst driving normal it just maybe doing its job as the roads atm are more often damp than not.
Post #589210 Fri Oct 25 2019 4:21am
MEC
Only will be perfect brand new less than 200 miles on them wondering is it possible I may have and overactive sensor maybe but if so which one
Post #589211 Fri Oct 25 2019 5:59am
Duc750
Right - its an 8% increase in tyre size so that really should make zero difference your best bet is to get it plugged in and try to capture some live data.
Have you actually put the old ones back on since the problem and are you sure the new ones are seating correctly ? 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #589233 Fri Oct 25 2019 12:20pm
MEC
Yes old wheels and tyres are back on and new ones fitted perfect they are genuine Land Rover wheels and tyres so at a bit of a loss thanks for your reply
Post #589235 Fri Oct 25 2019 12:35pm
Duc750
Is the offset the same between both wheels. If the offset on the new wheels is more +ve then you may be catching sensor wires or something. Problem is without some live data readings this could be impossible to trace.
That said we traced a problem on someone else's d2 with a GoPro strapped ubderneath. Might be an idea in the wheel arch. 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #589257 Fri Oct 25 2019 8:31pm
knwatkins
L494 20" wheels have an offset of et47. L320 20" wheels have an offset of et53.
The tyre is also 20mm narrower on the L494 wheels. Kev
Post #589258 Fri Oct 25 2019 8:48pm
Duc750
Not that then. It's all guess work without codes and live data. 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #589259 Fri Oct 25 2019 9:24pm
Tyrefitter
I don’t think the off set will make any difference as I’m running 45 off set with 30mm spacers so 32mm in total,I can’t think of what the problem is,if he is running all 4 same side it shouldn’t affect the TC.Ive also had these same wheels fitted to my12 red edition with no problems. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #589264 Sat Oct 26 2019 7:58am
MEC
Hi guys thanks for all all the head scratching it really is a problem could one of you explain what triggers dynamic stability control what sensors coming in to play could it be something to do with the height the cars sitting at or a steering angle sensor the only thing I can think of that's different with the new wheels is they are slightly taller and slightly narrower just driving the car 70 miles with old wheels and tires on no problems at all with the new ones did less than a mile car was undrivable thanks guys
Post #589268 Sat Oct 26 2019 9:41am
Brit Plumber
Can you get the VIN of the vehicle those wheels came off?
This is a screen shot of my car. The values shown could be something to do with stability control.
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #589271 Sat Oct 26 2019 11:31am
MEC
Will do but not till sunday thanks for your help
Post #589272 Sat Oct 26 2019 12:31pm
knwatkins
I agree. It would make no difference. Kev
Post #589275 Sat Oct 26 2019 1:03pm
1richard1
Old wheels on no problem new wheels on problems, get the new ones checked just because they are new doesn't mean there might not have an issue causing your problems.
Post #589277 Sat Oct 26 2019 1:09pm
Page 2 of 3 <123>
