![]() | Home > General > Range Rover Sport TDV6 56 Cylinder 6 Knocking/Tapping Video |
DCM51 Member Since: 26 Sep 2018 Location: Liecestershire Posts: 20 ![]() ![]() ![]() |
Good Morning Folks!
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
Wonder if you have a worn big end, possibly as a result of the overfueleing, diluting the oil somewhat.. |
Hey up Mikey!
Hopefully...all will hear the racket!!!! 🙄😖
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5019 ![]() ![]() ![]() |
if you want to inspect the shells you can do so by removing the sump.
Hi Andy,
yes, it was useful to locate it to cyl.6
I think the biggest issue is when we research issues such as these on the internet and the various diagnosis and opinions its very easy to get caught up in hysteria with potentially the worst case scenario!
Tom_w_27 Member Since: 09 Sep 2018 Location: Norfolk Posts: 40 ![]() ![]() ![]() |
If my understanding is right, you've replaced the injector and ruled that out it's not diesel knock.
Hi Tom,
drb1709 Member Since: 24 Aug 2019 Location: West Sussex Posts: 38 ![]() ![]() ![]() |
Injector might be OK, how about fuel delivery to it?
Without doubt you should see this through, I can't see any other way than pulling the engine out.
Hi Dave,
Too True fella! ![]() I must admit when I started to get much further in to why this Sport was suffering failure was described as being Turbo failure alone? Head Gasket left this engine soaked in Coolant, Fuel you name it! it was in it! The only bonus at the moment is that I have and continue to learn a lot about this Engine therefore every cloud has a silver lining I suppose. I bet I have saved a penny or two already! |
