Home > Faults & Fixes > Rrs tdv8 2007 no coolant warning
Terryok
Had a problem with burst water hose on above rrs car overheated but no warning no light no low coolant nothing temp gauge stayed halfway as normal only indication was steam with is not ideal as you can imagine, read somewhere there is no low coolant message on this model or even a light that comes on to warn this seems not right can anyone enlighten me please ??
Post #588066 Sat Oct 05 2019 9:01am
DCM51
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Hello mate,
As far as I am aware the message centre on the dashboard should read something like "CHECK COOLANT LEVEL".
Also there are wires leading to the Coolant expansion valve which are obviously tied in to the ECU etc to warn of any potential issue within the cooling system.
Post #588076 Sat Oct 05 2019 11:25am
geoffsnook
Yes it will warn you when the coolant is low as suggested it is in the middle of dash but i think it can be turned off with a IDD tool but stand to be corrected as usual Thumbs Up
Post #588149 Sun Oct 06 2019 11:24am
Terryok
Thanks all rekon been turned off
Post #588200 Mon Oct 07 2019 11:00am
PC76
The float in the water bottle becomes stuck over time. this would cause either a permminament low level warning or not allow the warnign at all.
you need to replace the bottle (also comes with a new sensor) as there is no current way of resolving.
Post #588203 Mon Oct 07 2019 11:17am
Terryok
Thank you will investigate
Post #588303 Tue Oct 08 2019 9:45pm
