Home > Faults & Fixes > Rrs tdv8 2007 no coolant warning |
DCM51 Member Since: 26 Sep 2018 Location: Liecestershire Posts: 20 |
Hello mate,
Sat Oct 05 2019 11:25am |
Yes it will warn you when the coolant is low as suggested it is in the middle of dash but i think it can be turned off with a IDD tool but stand to be corrected as usual |
Sun Oct 06 2019 11:24am |
Terryok Member Since: 06 Jul 2019 Location: Kent Posts: 24 |
Thanks all rekon been turned off |
Mon Oct 07 2019 11:00am |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
The float in the water bottle becomes stuck over time. this would cause either a permminament low level warning or not allow the warnign at all.
Mon Oct 07 2019 11:17am |
Thank you will investigate |
Tue Oct 08 2019 9:45pm |
