![]() | Home > Faults & Fixes > Rrs tdv8 2007 no coolant warning |
DCM51 Member Since: 26 Sep 2018 Location: Liecestershire Posts: 20 ![]() ![]() ![]() |
Hello mate,
Yes it will warn you when the coolant is low as suggested it is in the middle of dash but i think it can be turned off with a IDD tool but stand to be corrected as usual |
Terryok Member Since: 06 Jul 2019 Location: Kent Posts: 24 ![]() ![]() ![]() |
Thanks all rekon been turned off |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
The float in the water bottle becomes stuck over time. this would cause either a permminament low level warning or not allow the warnign at all.
Thank you will investigate |
