Home > Technical > EPB Woes and a Question
Brit Plumber
Do you know that the original setup includes Tv ariels in the rear side windows? You may not have the required connection point. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #586847 Fri Sep 13 2019 7:09am
derekmines
gogsy1956 wrote:
I can certainly look,,,, but you will have to wait until next week as I am in Dubai at the moment and won't be back home until next Wednesday.
Lucky man, I lived there for 5 years and loved every minute of it. A great place.
Post #586850 Fri Sep 13 2019 7:25am
derekmines
I can see little press stud type connectors on the rear side windows that I believe are for the antennas, I'll need to buy them as well but hopefully the basic wiring is already there.
Post #586851 Fri Sep 13 2019 7:27am
Brit Plumber
I think you’re good with the press studs then. I have some window amplifiers you have for the postage cost, I don’t think the wiring is there but I have co-ax cabling to if you want that too. I’d need to look at the diagrams to see how much difference there is to the 2012MY but it’s not to difficult to wire in. 2019 5.0 SC SVA (Current)
Post #586857 Fri Sep 13 2019 8:38am
Click on the file, may help.
http://www.rrsport.co.uk/gallery/displayim...&pos=0
Post #586858 Fri Sep 13 2019 8:49am
derekmines
May Help
Lol, that's brilliant, simply brilliant. Talk about moving my project on!
Cheers, a virtual pint in your direction.
Post #586870 Fri Sep 13 2019 11:24am
derekmines
gogsy1956 wrote:
I've been down this road,, even cutting the cables didn't free off the discs, ended up with new disc's and Epb module etc
So we tried everything this afternoon but ended up having to cut the cable from one side which immediately freed off the brake on that side and allowed us to manually free off the other side.
The module is now removed from the car and I shall see about ordering a replacement now...
Strangely, although the car drives, the fuel gauge no longer works and the range computer reports 0 miles... I wonder if the sender somehow runs through the same loom as the EPB control?
Post #586889 Fri Sep 13 2019 5:47pm
Oldandconfused
When I had EPB issues, I was advised to pull the fuse to prevent accidentally applying it (you just do it automatically). When I did this the fuel gauge stopped working and I was concerned that the car would think it was out of fuel and cut out (it has a protocol to prevent the injection system drying out, have a search for faulty fuel gauge senders) so put it back and stuck tape over the switch till my garage could fit it in. Did you pull the fuse? If so try putting it back.
Post #586936 Sat Sep 14 2019 9:07am
derekmines
It appears that the fuel gauge must run through that same loom somehow and once the handbrake module had been replaced and reconnected electrically the fuel level was reported again!
Post #587373 Mon Sep 23 2019 11:29am
Oldandconfused
Typical Land Rover eh.
Post #587401 Mon Sep 23 2019 4:48pm
