![]() | Home > Technical > EPB Woes and a Question |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
Lucky man, I lived there for 5 years and loved every minute of it. A great place. |
I can see little press stud type connectors on the rear side windows that I believe are for the antennas, I'll need to buy them as well but hopefully the basic wiring is already there. |
I think you’re good with the press studs then. I have some window amplifiers you have for the postage cost, I don’t think the wiring is there but I have co-ax cabling to if you want that too. I’d need to look at the diagrams to see how much difference there is to the 2012MY but it’s not to difficult to wire in. 2019 5.0 SC SVA (Current)
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Click on the file, may help.
May Help
So we tried everything this afternoon but ended up having to cut the cable from one side which immediately freed off the brake on that side and allowed us to manually free off the other side. The module is now removed from the car and I shall see about ordering a replacement now... Strangely, although the car drives, the fuel gauge no longer works and the range computer reports 0 miles... I wonder if the sender somehow runs through the same loom as the EPB control? |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
When I had EPB issues, I was advised to pull the fuse to prevent accidentally applying it (you just do it automatically). When I did this the fuel gauge stopped working and I was concerned that the car would think it was out of fuel and cut out (it has a protocol to prevent the injection system drying out, have a search for faulty fuel gauge senders) so put it back and stuck tape over the switch till my garage could fit it in. Did you pull the fuse? If so try putting it back. |
It appears that the fuel gauge must run through that same loom somehow and once the handbrake module had been replaced and reconnected electrically the fuel level was reported again! |
Typical Land Rover eh. |
