Home > Technical > EPB Woes and a Question
derekmines
So it's become obvious that my EPB module is toast (horrible noises, emergency release doesn't work etc etc) and I need to arrange a replacement.
However at the moment the car cannot be driven as the parking brake is seized on.
Since I believe I'm right in saying that the new module comes with the cables attached, is there any reason my mobile mechanic can't cut the current cables to free off the shoes, allowing the car to be driven to the garage who will replace the part?
Post #586752 Wed Sep 11 2019 5:54pm
geoffsnook
You sure the release dont work it needs a serious pull Thumbs Up
Post #586753 Wed Sep 11 2019 5:57pm
derekmines
Yep, I got the jack handle out of the boot, threaded it through the loop and gave it the full beans, the cable itself pulls just fine, it's just like there's nothing on the end of it!
Post #586760 Wed Sep 11 2019 6:50pm
geoffsnook
You can cut the cables but depends on why they are stuck if its just bad adjustment may be worth also looking to see if the shoes can be backed off at all if there stuck solid you may not get the holes to line up with adjuster i assume as the cable has been pulled the arm in the epg has released have a look at bodseys brake bible i know its on disco3 under the wiki Thumbs Up
Post #586761 Wed Sep 11 2019 7:27pm
derekmines
Tried to back them off this afternoon, unfortunately they are stuck solid so, as you say, we cannot get the discs to line up - I'm really struggling to see another way other than cutting the cables!
Post #586762 Wed Sep 11 2019 7:29pm
Disco_Mikey
Remove EPB cover and unjam module
Cutting cables leads to a whole world of unnecessary expense Thumbs Up
Post #586765 Wed Sep 11 2019 7:49pm
geoffsnook
Well i think you will have to cut cables and hope they release the shoes from the discs and maybe rap the discs to get them in
Post #586766 Wed Sep 11 2019 7:51pm
derekmines
Agreed, but I can't see how that's possible on the side of the street with no ramp / lift
Post #586775 Wed Sep 11 2019 9:04pm
Disco_Mikey
Unjammed many of them at the side of the road when I used to be mobile. Its not a huge drama Thumbs Up
Post #586776 Wed Sep 11 2019 9:12pm
derekmines
Can you give me a hint or 3 as to how, my mobile mechanic hasn't done one before and couldn't see how to unjam in-situ
Post #586777 Wed Sep 11 2019 9:27pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
He has already made a great thread on disco3, https://www.disco3.co.uk/forum/epb-repairu...EPB+repair
Post #586779 Wed Sep 11 2019 10:27pm
gogsy1956
I've been down this road,, even cutting the cables didn't free off the discs, ended up with new disc's and Epb module etc 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #586793 Thu Sep 12 2019 12:35pm
derekmines
I think you're probably right, moment of truth tomorrow afternoon!
On another subject Gogsy could you possibly grab me the part numbers from your TV tuner module, we have the same model year of car and one of the things I want to do is retrofit the TV system but I need to know the correct digital module to look for lol - cheers!
Post #586819 Thu Sep 12 2019 7:30pm
Brit Plumber
AH is the 2010 code so it should be something like AH22 or AH42.
AH42-19C063-AC or AE will work 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #586837 Thu Sep 12 2019 10:32pm
gogsy1956
I can certainly look,,,, but you will have to wait until next week as I am in Dubai at the moment and won't be back home until next Wednesday. 2010 RRS, TDV8
22" overfinch
Post #586842 Fri Sep 13 2019 3:18am
