Home > General > Gearbox Flush
drb1709
Gearbox Flush
What are the views on sucking out the gearbox fluid and changing it that way.
Just been quoted over £600 from stealers, was only thinking of a bit of preventative maintenance.
If OK, any suggestions in Sussex?
Thanks
Dave
Post #586296 Tue Sep 03 2019 5:58pm
Disco_Mikey
Find someone with a flushing machine. Cost is approx half that of a main dealer, with 3x the amount of oil replaced Thumbs Up
Post #586299 Tue Sep 03 2019 6:21pm
drb1709
Thanks, that was what I was thinking, but is the filter likely to be clogged, or is it more a case of the oil degenerating?
Post #586303 Tue Sep 03 2019 6:25pm
knwatkins
If you're going to suck it out, you may as well drain it out through undoing the plug. However, that will only get a couple of litres out as a lot of the fluid is in the torque converter.
Using a pressure sprayer, a bit of garden hose and a few jubilee clips it's dead easy to do a full fluid flush yourself through the gearbox fluid cooler just behind the front bumper.
This is what the cooler looks like. The two straight pipes are for the coolant flow, the two right angled pipes are for the gearbox fluid flow. When your engine is running, the pump in your gearbox pumps the fluid from the gearbox into the cooler via the right hand pipe, through the cooler, out of the left hand pipe and back into the torque convertor where it then flows back into the gearbox.
What you need to do is:
1. Remove the hose with the quick connector from the right hand pipe on the cooler
2. Connect your pressure sprayer to the cooler pipe disconnected in step 1
3. Position the hose with the quick connector over the top of a container to catch your old dirty fluid
4. Turn the engine on and pump as much fluid out of the gearbox as possible
5. Pump the same amount back in through the cooler using your pressure sprayer
Repeat steps 4 and 5 until the fluid being pumped out of the box is nice and clean.
A final fluid level check at the end is needed. You will need to run the engine until the fluid hits 40 degrees C, keeping the engine running, undo the filler plug on the side of the gearbox and the fluid should be a small trickle. Drain/top up as necessary.
For me, I ended up using about 20 litres of fluid. Most guys use around 12 litres. I'm just ultra fussy.
Many Disco and RRS owners use Mannol AG55 in the 6 speed box, AG60 for the 8 speed.
Mine is a 6 speed so I purchased 20 litres of AG55 for around £65 delivered from Germany: https://www.motor-oel-guenstig.de/schmiers...uessigkeit
I hope this helps Thumbs Up Kev
Post #586308 Tue Sep 03 2019 8:15pm
drb1709
Thanks very much, that'll be the way forward.
Dave
Post #586319 Wed Sep 04 2019 7:54am
DrRob
Flush in Sussex here
http://www.sandgautocare.co.uk/
Thumbs Up Visitor from fullfatrr.com
Post #586352 Wed Sep 04 2019 6:20pm
drb1709
Brilliant, thanks, and only 15 mins from me.
Dave
Update - Colleague going to R&G on Monday for full flush, me also the week after.
£270 seems excellent value, and they say 100% oil changed.
Thanks for the lead,
Dave
Post #586354 Wed Sep 04 2019 6:26pm
drb1709
My thanks to Dr Rob.
Had gearbox flush and engine carbon clean at R&G in Lancing.
Dave knows his stuff and will be my new 'Indie'.
Cheers all.
Dave
Post #587602 Thu Sep 26 2019 10:35am
not quite 100%. Maybe 95%
Post #587604 Thu Sep 26 2019 11:08am
DrRob
Cheers all.
Dave
Good to hear Thumbs Up I make it my business to know where the good indies are to help others. The flushing kit he has there is Geoff's old machine from the Disco forum Thumbs Up Visitor from fullfatrr.com
Post #587607 Thu Sep 26 2019 11:28am
keith63
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Hi All
is this Gearbox Flush A regular maintenance task
how often should it be done ?
I am not noticing anything wrong with the Gearbox..
but do have 101k on clock
what are the recommendations ?
cheers
k
Post #587610 Thu Sep 26 2019 11:51am
PC76
Hi Keith,
definatly worth doing every 70k... i had mine done at 115k if i remember correctly and it made a massive differece to the smoothness so much so i coulndt tell if it had changed gear if on a lazy drize.....
Post #587612 Thu Sep 26 2019 11:54am
Rangey Davey
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Java Black
Does anyone know where I could get a gearbox flush done near High Wycombe in Bucks? 2006 HSE
4.4 V8
JAVA BLACK
Post #587613 Thu Sep 26 2019 12:02pm
knwatkins
Keith, ZF, the manufacturer of the gearbox recommend a flush every 80,000 to 120,000 kilometers (every 50k to 75k miles) OR 8 years, whichever is sooner.
It's easy enough to do yourself, just search the disco forum. Kev
Post #587617 Thu Sep 26 2019 2:53pm
DrRob
Ian Bodsworth (Bodsy) is the mobile flushing guru Thumbs Up
Best text him on 07770 638023
Post #587620 Thu Sep 26 2019 3:45pm
