Home > General (L494) > My16 DPF ssues ...41.5k miles on vlock
Page 2 of 3 <123>
Tyrefitter
It’s grams I meant not percent,don’t know why I said % but anything over 30 grams puts it in limp mode on later models,the earlier ones were 60% I suppose they made it lower as not to Knacker the dpf. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #586198 Sun Sep 01 2019 11:30am
Ash3
Spleen wrote:
Hmm, I wonder how much percent 31 grams represents?
Yep I see it....think that used to be called the butterfly valve on the old disco3...remember removing it when blanked the egr valves. Thumbs Up
Post #586199 Sun Sep 01 2019 11:34am
Tyrefitter
The black plastic housing is the throttle body that I got replaced under warranty. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #586200 Sun Sep 01 2019 11:37am
Tyrefitter
If it is the throttle body that’s Censored their is one here if you don’t get it fixed under warranty
https://www.ebay.co.uk/itm/for-RANGE-ROVER...Swd01dLbM~ Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #586201 Sun Sep 01 2019 11:40am
Ash3
Thanks Tyrefitter
Greatly Appreciate all the info & advice.
Post #586212 Sun Sep 01 2019 3:32pm
Ash3
Update..
Going through the menue in the display...found that engine oil level had been overfilled.
Spoke ro an independent LR specialist...he advised that could result EML lighting up and cause dpf to not regenerate...wbich is much what the dealer I bought it from said.
Car is booked in for diagnostic and oil change along with dpf clean on Wednesday.
Post #586234 Mon Sep 02 2019 11:01am
Ash3
Post #586235 Mon Sep 02 2019 11:02am
timhum
From the photo it appears that you have checked the oil with the engine cold. I think the handbook says to run the engine, let it settle and then do the check. I found this out from personal experience and getting the same message. Apologies if I've come to the wrong conclusion.
Tim Tim
RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame..
Post #586252 Mon Sep 02 2019 7:47pm
Ash3
Hi Tim,
Just checked the manual and you are correct.
However, oil expands to some degree when it is hot so would a cold reading not show high levels? Particularly after running engine to temp and allowing 10mins for it drain back into the pan.
I dont suppose anyone could check their oil level on a cold engine and post a photo on here showing the reading and then check again in accordance with the manual. That would be really appreciated. It would help acsertain what I should be seeing.
I would really be helpful Thumbs Up
Post #586261 Mon Sep 02 2019 10:04pm
timhum
Ash3,
I speak from experience on this, if I check the oil level cold it shows overfilled and after running the engine and then leaving for a few minutes reading is OK. When cold all the oil will have drained into the sump, after running the engine it will be distributed throughout the engine.
Tim Tim
Post #586262 Mon Sep 02 2019 10:42pm
Ash3
Cheers Tim
That is good to know Thumbs Up
Though I am reluctant to turn engine on and run it for 10mins whilst I got the red dpf warning.
Post #586281 Tue Sep 03 2019 2:08pm
Ash3
Tyrefitter wrote:
This is the report the technician game me.
Hi All
Just wanted to update you all.....got the car back about 3 weeks ago..problem all sorted. Thumbs Up
What was the issue????.......Stuck throttle body as some you have experienced. The stuck throttle body caused the EML warning light which was as result of the syuck throttle body causing the turbocharger overboost condition falut code in addition to causing dpf red warning light.
Throttle body replaced and dpf was cleared by taking it for a blast at high revs allowing dpf to regenerate normally......similar problem to Andy I believe.
Also had oil and oil filter changed due to oil ovrrgil. Was told it was overfilled by half a litre or so....Thank God it did not cost me anything other than inconvenience in loss of car for a week
The car dealer i bought it off paid for the works...consumer protection act 2015...great piece of legislation Thumbs Up
Post #587355 Sun Sep 22 2019 11:24pm
Ash3
And here she is.
Post #587356 Sun Sep 22 2019 11:25pm
ilard
Great outcome.
I have a suggestion, use a fuel treatment to keep things tickety-boo going forwards. See my Archoil AR6400-D and AR6900-D post just now: https://www.rrsport.co.uk/forum/topic54747.html L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #587417 Tue Sep 24 2019 6:33am
Ash3
Thanks ilard....good idea. Thumbs Up
Post #587962 Thu Oct 03 2019 5:41pm
Page 2 of 3 <123>
