Home > General (L494) > My16 DPF ssues ...41.5k miles on vlock |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
Yep I see it....think that used to be called the butterfly valve on the old disco3...remember removing it when blanked the egr valves. |
Sun Sep 01 2019 10:34am |
The black plastic housing is the throttle body that I got replaced under warranty. Andy.
Sun Sep 01 2019 10:37am |
If it is the throttle body that’s their is one here if you don’t get it fixed under warranty
Sun Sep 01 2019 10:40am |
Thanks Tyrefitter
Sun Sep 01 2019 2:32pm |
Update..
Mon Sep 02 2019 10:01am |
Mon Sep 02 2019 10:02am |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 |
From the photo it appears that you have checked the oil with the engine cold. I think the handbook says to run the engine, let it settle and then do the check. I found this out from personal experience and getting the same message. Apologies if I've come to the wrong conclusion.
Mon Sep 02 2019 6:47pm |
Hi Tim,
Mon Sep 02 2019 9:04pm |
Ash3,
Mon Sep 02 2019 9:42pm |
Cheers Tim
Tue Sep 03 2019 1:08pm |
Hi All Just wanted to update you all.....got the car back about 3 weeks ago..problem all sorted. What was the issue????.......Stuck throttle body as some you have experienced. The stuck throttle body caused the EML warning light which was as result of the syuck throttle body causing the turbocharger overboost condition falut code in addition to causing dpf red warning light. Throttle body replaced and dpf was cleared by taking it for a blast at high revs allowing dpf to regenerate normally......similar problem to Andy I believe. Also had oil and oil filter changed due to oil ovrrgil. Was told it was overfilled by half a litre or so....Thank God it did not cost me anything other than inconvenience in loss of car for a week The car dealer i bought it off paid for the works...consumer protection act 2015...great piece of legislation
Sun Sep 22 2019 10:24pm |
And here she is. |
Sun Sep 22 2019 10:25pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
Great outcome.
Tue Sep 24 2019 5:33am |
Thanks ilard....good idea. |
Thu Oct 03 2019 4:41pm |
