Home > Maintenance & Modifications > Turbo oil drain mod |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
The ARC system runs at pressures upto 150bar
Fri Oct 18 2019 11:48am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 897 |
As a design engineer of more years than I want to remember if you have the correct rated fittings there is nothing wrong with it. For example from Parker catalogue 8mm O.D. tubing with 1.5mm wall material low carbon steel is rated at 431 bar & in Stainless is rated at 472 bar
Fri Oct 18 2019 12:30pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
I completely agree with you Lindab. Brit_Plumber's fittings were rated at 3000 bar so 150 bar is nothing in comparison.
Fri Oct 18 2019 12:53pm |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
sorry for back tracking! do the key fobs not self charge themselves? The FFRR ones used to! Maybe someone can clarify this. Current: 2010 RRS 3.6 TDV8 HSE
Tue Oct 22 2019 6:09am |
