Home > Maintenance & Modifications > Turbo oil drain mod
Disco_Mikey
The ARC system runs at pressures upto 150bar
I wouldn't be confident of putting fittings in the pipework...
The pipes are not that expensive, and its only 4-5hrs of labour
Post #588833 Fri Oct 18 2019 11:48am
knwatkins
I believe Brit_Plumber on here repaired his hydraulic pipes with compression fittings.
As long as the solution is well engineered and therefore specified and rated adequately, I don't see it being a problem. The problem comes when some numpty nips down to Screwfix and grabs a fitting meant to be used on central heating!
Obviously a garage wouldn't do this because they can easily lift the body, fit the replacement bits and jobs a good'un. However, not everyone has the facility to lift the body to replace the parts in their entirety. Kev
Post #588836 Fri Oct 18 2019 12:12pm
Lindab
As a design engineer of more years than I want to remember if you have the correct rated fittings there is nothing wrong with it. For example from Parker catalogue 8mm O.D. tubing with 1.5mm wall material low carbon steel is rated at 431 bar & in Stainless is rated at 472 bar
I do not know what size tubing you are talking about but that is just an example. Give me the tube sizes & material & I can give you the ratings.
Post #588840 Fri Oct 18 2019 12:30pm
knwatkins
I completely agree with you Lindab. Brit_Plumber's fittings were rated at 3000 bar so 150 bar is nothing in comparison.
For reference, his thread is here: https://www.rrsport.co.uk/forum/topic51144.html Kev
Post #588846 Fri Oct 18 2019 12:53pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
sorry for back tracking! do the key fobs not self charge themselves? The FFRR ones used to! Maybe someone can clarify this. Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #589053 Tue Oct 22 2019 6:09am
