Home > General > Vibration at speed worse braking at speed
Ade1882
Scotland 2007 Range Rover Sport TDV8 HSE Santorini Black
Just got myself a 2007 tdv8 rrs, I was aware of an issue under braking at speed when I bought it and assumed (was told by the seller) that the discs needed skimmed. I have now noticed that there is a very slight vibration through the steering wheel at speed 60mph or so, which gets worse under braking. It’s not noticeable at low speeds.
Would this suggest it’s not warped discs and does anyone know what it is likely to be?
I have searched the forum but can’t find anything that mentions vibration both under braking and at speed.
Thanks for any help given.
Post #585328 Wed Aug 14 2019 7:50am
ondafly
Ireland 2007 Range Rover Sport TDV6 HSE Java Black
are the wheels/tires balanced ? that would be my first port of call.
Post #585329 Wed Aug 14 2019 8:03am
Ade1882
Cheers, I’ll probably try this first but would it be worse under braking if the wheels/tires need balanced. The car looks to have been sitting for quite a while without moving much before I got it.
Post #585332 Wed Aug 14 2019 8:48am
Pufftmw
Sticky calliper? Front wheel bearing?
Check the heat of each wheel after a small drive and if one is hotter than the other, then this will likely be the cause.
Obviously don't touch the wheel/disc if its likely to be very hot!!
Post #585342 Wed Aug 14 2019 4:32pm
daxmatt
mine did the same,changed bottom bones,cured Very Happy
Post #585345 Wed Aug 14 2019 6:29pm
gogsy1956
As the guys have said,, wheel balance and / or sticky caliper. I've had the same issue, the very small vibration through the steering wheel turned out to be an out of shape front wheel. Vibration under braking was a sticky caliper, more noticable through the brake pedal, front wheel bearing will be more noticable when driving round a bend.
I don't think I would go down the road of skimming discs though,, replace with new if they are worn or warped. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #585346 Wed Aug 14 2019 6:32pm
Front lower arm bushes will cause this too. If they're original on a 2007 then they're due a change. 2012 SDV6 - it's missing a couple of cylinders
Post #585357 Wed Aug 14 2019 10:37pm
Ade1882
I’ve checked the Cali per temperatures and they both seem pretty similar. Warm but not too hot.
I’m booking it in for the wheel balancing as a first stop. Is the bush replacement an expensive job if it’s that?
Post #585361 Thu Aug 15 2019 6:24am
Ade1882
And will a garage be able to tell straight away if it’s the bottom bones or the bushes?
Thinking after the wheel balancing I just stick it in somewhere to get it look at (unless it’s fixed of course)and make a few suggestions as per what’s been said on this post.
It’s a long shot but anyone know a good garage for Range Rovers in Aberdeen. Not keen to put it too the main dealer.
Post #585362 Thu Aug 15 2019 6:29am
Pufftmw
Don't know about Aberdeen but MMP in Dundee would be a worthwhile trip down @Disco_Mikey is a regular on here and an LR specialist.
Post #585367 Thu Aug 15 2019 11:00am
knwatkins
Also be sure to feed back to us on how you get on. Always useful for other people in the future Thumbs Up Kev
Post #585369 Thu Aug 15 2019 11:55am
wilf
Just a thought - if the car had, as you say, been sitting for a while - tyres flat-spotted? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #585394 Thu Aug 15 2019 8:56pm
Danchez
Think that's the only thing I haven't changed..... Laughing
Post #587538 Wed Sep 25 2019 5:23pm
knwatkins
Lower wishbones aka control arms Kev
Post #587540 Wed Sep 25 2019 5:38pm
Danchez
Thanks Thumbs Up
Post #587541 Wed Sep 25 2019 5:41pm
