![]() | Home > General > Vibration at speed worse braking at speed |
Ade1882 Member Since: 14 Aug 2019 Location: Aberdeen Posts: 10 ![]() ![]() ![]() |
Just got myself a 2007 tdv8 rrs, I was aware of an issue under braking at speed when I bought it and assumed (was told by the seller) that the discs needed skimmed. I have now noticed that there is a very slight vibration through the steering wheel at speed 60mph or so, which gets worse under braking. It’s not noticeable at low speeds.
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 ![]() ![]() ![]() |
are the wheels/tires balanced ? that would be my first port of call. |
Cheers, I’ll probably try this first but would it be worse under braking if the wheels/tires need balanced. The car looks to have been sitting for quite a while without moving much before I got it. |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 194 ![]() |
mine did the same,changed bottom bones,cured |
As the guys have said,, wheel balance and / or sticky caliper. I've had the same issue, the very small vibration through the steering wheel turned out to be an out of shape front wheel. Vibration under braking was a sticky caliper, more noticable through the brake pedal, front wheel bearing will be more noticable when driving round a bend.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9058 ![]() ![]() ![]() |
Front lower arm bushes will cause this too. If they're original on a 2007 then they're due a change. 2012 SDV6 - it's missing a couple of cylinders
I’ve checked the Cali per temperatures and they both seem pretty similar. Warm but not too hot.
And will a garage be able to tell straight away if it’s the bottom bones or the bushes?
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Don't know about Aberdeen but MMP in Dundee would be a worthwhile trip down @Disco_Mikey is a regular on here and an LR specialist. |
Also be sure to feed back to us on how you get on. Always useful for other people in the future |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Just a thought - if the car had, as you say, been sitting for a while - tyres flat-spotted? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Danchez Member Since: 21 Aug 2018 Location: Oxfordshire Posts: 5 ![]() ![]() |
Think that's the only thing I haven't changed..... ![]() Last edited by Danchez on Wed Sep 25 2019 5:40pm. Edited 1 time in total |
Lower wishbones aka control arms Kev
Thanks |
