Home > General > blistering paintwork
Rusty Novice
England 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Bingo!!
The actual areas of blistering are magnetic but on further inspection part of the wheel arch is not so a bodged repair is the conclusion Censored
Verified by comparing it to the other side as well.
Thanks you guys for all your inputs .Now to see what the best cause of action is !
Post #584992 Mon Aug 05 2019 4:36pm
Brit Plumber
So it’s probably a wet sanded piece of body filler that the moisture is leeching out of in the heat. Probably going to be a case of removing the paint, the filler and re-applying. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #585038 Tue Aug 06 2019 6:27pm
Rusty Novice
Those blistered areas are magnetic so oxidisation of the zinc plating caused by its partial removal by sanding/blending in in the repair shop is more likely rather than filler buddy.
I know a local lad whose mustard on panel repair work so I am going to run this by him for a opinion of whats the best cause of action Thumbs Up
Post #585039 Tue Aug 06 2019 6:38pm
