Home > General > blistering paintwork
Rusty Novice
England 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Jan 2013 model
I have just noticed several areas on the rear drivers side wing where the paintwork looks like its blistered above the wheel arch!!
Now I read somewhere that with the exception of the bonnet and rear boot which are aluminium the rest of the panels are zinc powder coated prior to being primed and sprayed so I'd be surprised if this was corrosion or I hope its not to be honest. Big Cry
On closer inspection its almost like something was on the panel prior to being sprayed.
I'll attach a picture
What do you reckon? Shocked
Post #584879 Fri Aug 02 2019 8:17pm
Brit Plumber
Do you know the history of the car? It could be a repaired panel after damage. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584884 Fri Aug 02 2019 9:47pm
Tom_w_27
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Looks like it's rusting from the inside out??
Post #584886 Fri Aug 02 2019 9:54pm
Rusty Novice
I'm afraid I don't know the history buddy
Took a leap of faith earlier and REALLY pressed hard on the largest affected area as I could and relieved to say its solid underneath.
Vehicle is 6yr10mth old and the manufacturers warranty for bodywork is 6years Censored so really Censored off at the moment tbh Sad
Could it be a reaction to diesel spillage from the previous owners ?
Post #584917 Sat Aug 03 2019 5:42pm
DEVON
I doubt it’s diesel, but could be wrong.
Looks to me like a reaction to a chemical that has been spilt/splashed onto the paintwork Big Cry
Post #584921 Sat Aug 03 2019 7:35pm
Looks a bit like it's actualy under the paint to me, not sure what would cause it unless posibly a flaw in prep. from new.
Post #584930 Sat Aug 03 2019 11:55pm
garrycol
Australia
It looks like aluminium/galvanising surface corrosion under the paint. If you were to scrape the paint away I bet there is a white powder (the equivalent of iron oxide with a steel panel) under the paint. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #584933 Sun Aug 04 2019 2:32am
Brit Plumber
Could the OP post a wider angle photo? Give us an idea of where on the vehicle and the direction of the marks. I’ve seen similar when body filler has been wet sanded and not had chance to dry before being painted. The filler is hdrascopic and the moisture leaches out. 2019 5.0 SC SVA (Current)
Post #584936 Sun Aug 04 2019 8:24am
Brit Plumber
Just re-read the first post, I wonder if it could be brake fluid contamination? Not sure how it affects modern paints. 2019 5.0 SC SVA (Current)
Post #584937 Sun Aug 04 2019 8:35am
J.Prezes
Poland 2011 Range Rover Sport Supercharged Autobiography Santorini Black
Brake fluid chews through everything, including modern paints. Factory service manuals (for sure Subaru) always have something that goes like this "always wash off spilt brake fluid because it is corrosive or will damage painted surfaces or whatever". So that is a possibility.
Post #584946 Sun Aug 04 2019 12:32pm
Rusty Novice
Follows the contour of the wheel arch just as it flares out
Could be a repair??
Post #584971 Sun Aug 04 2019 9:44pm
Rusty Novice
I know the later models are aluminium . I'm under the impression this model is steel .However I read somewhere the panels are zinc galvanised/plated first which would make them very robust indeed but I can't seem to find that link or any info regarding the L320 construction .I'm hoping yourself or anyone of the knowledgeable guys on here can provide that information
The thought has crossed my mind though but I'm not brave enough to get sharp implement out yet!
Post #584972 Sun Aug 04 2019 9:49pm
Lindab
Looks like brake fluid. Have you fallen out with anyone lately?
Post #584974 Sun Aug 04 2019 10:30pm
Brit Plumber
If it was vandalism I’d expect to see it on the bonnet and doors rather than a few bits at the rear.
I bet your already looking at getting it repainted. 2019 5.0 SC SVA (Current)
Post #584976 Sun Aug 04 2019 11:08pm
Mister B
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Magnate ?
Post #584978 Mon Aug 05 2019 8:24am
