![]() | Home > General > blistering paintwork |
So it’s probably a wet sanded piece of body filler that the moisture is leeching out of in the heat. Probably going to be a case of removing the paint, the filler and re-applying. 2019 5.0 SC SVA (Current)
Rusty Novice Member Since: 04 May 2018 Location: Staffordshire Posts: 34 ![]() ![]() ![]() |
Those blistered areas are magnetic so oxidisation of the zinc plating caused by its partial removal by sanding/blending in in the repair shop is more likely rather than filler buddy.
