Home > General > 2015 RRS Blank Entertainment screen
eazy
Hi guys just recently purchased a 65 plate rrs. Yesterday after driving the car the navigation screen had went blank. All the side buttons are on but no radio , parking sensors or anything is working. Screen wont come on at all.
Have already hard reset the car via the battery and checked some fuses but nothing so far! Anyone expieranced these issues?
Thanks!
Post #584221 Sat Jul 20 2019 10:14pm
Lee1977
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
if you purchased from a dealer I would take it back to to dealer to resolve assuming its under warrenty Current RRS MY2012 HSE Lux 3.0 SDV6 Orkney Grey
Gone Audi A6 Salon 2.ltr Black Edition Daytona Grey- disappointing needs 6 cylinders
Gone RRS MY2010 HSE 3.0 TDV6 Stornoway Grey - written off!!
Gone BMW 330d M Sport - Epic engine still missed
Post #584232 Sun Jul 21 2019 6:46am
eazy
Hi mate i bought the car privately and unfortunately out of warranty now!
Post #584263 Sun Jul 21 2019 6:56pm
Lee1977
Hi thought that you just have bought privatley but did not want to assume.
Do you have code reader? or know someone that has one?
If not you ought have to bite the bullet and take it to a dealer or local specialist.
Hope you manage to get the issue resolved. Current RRS MY2012 HSE Lux 3.0 SDV6 Orkney Grey
Post #584268 Sun Jul 21 2019 7:11pm
Brit Plumber
Have you checked your fuses?
Similar issues are caused by dampness entering the Amp, had it rained or did you wash the car before hand? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584272 Sun Jul 21 2019 7:30pm
eazy
Quick update, just had it in at land rover where they used a hour on the car. Called me back today and are asking for permission for another 4 hours because they believe the fault isn between head unit and amp.. £156 a hour though so before they even fix the problem its going to be £780 odds without any additional parts ontop. Any opinions guys?
Post #585058 Wed Aug 07 2019 7:53am
Brit Plumber
So they are implying it’s a wiring issue or MOST. MOST should be easy to diagnose as it’s a loop, if it’s broken, it doesn’t work.
So wiring, not difficult, there’s only a few for power. Not sure where the AMP is on your car but I’d still be a bit sus. 2019 5.0 SC SVA (Current)
Post #585063 Wed Aug 07 2019 8:18am
Have a feeling the Amp is under the front passenger's seat, not sure if possible but might be worth having a look to see if connections have been knocked in some way by rear seat passenger.
Post #585064 Wed Aug 07 2019 8:29am
eazy
Thanks for the replys guys! So basically they want to strip it down from the amp to the headunit and test the wiring and see where the fault is, basically saying 5 hours labour + any parts needed ontop. Also they couldn't garuntee it would be fixed. im absolutely confused with it!
Post #585070 Wed Aug 07 2019 5:32pm
Brit Plumber
You shouldn’t need to strip the car to test wiring! It’s a 30 minute job to do a continuity and insulation test. I have a suspicion they know there is an issue and need to get to it.
Did you say you had audio still? And can control it with the volume knob? 2019 5.0 SC SVA (Current)
Post #585071 Wed Aug 07 2019 6:19pm
Brit Plumber
Can you read this?
Link
https://static.nhtsa.gov/odi/tsbs/2015/MC-10104861-9340.pdf
What do you think? 2019 5.0 SC SVA (Current)
Post #585072 Wed Aug 07 2019 6:28pm
eazy
Once again, thanks for replys, the screen is absolutely blank. No symbol comes on at all and no radio audio or parking sensors work. The buttons at the sides of the nav light up and can be pushed but dont respond! Tried fuses and hard resettong car also. Hard lne !
Post #585073 Wed Aug 07 2019 6:32pm
Brit Plumber
Another possibility.
https://static.nhtsa.gov/odi/tsbs/2016/SB-10106082-9340.pdf
This is what I was expecting, see if you can find any damp near the amp. It could be quite difficult to detect. 2019 5.0 SC SVA (Current)
Post #585074 Wed Aug 07 2019 6:44pm
eazy
Land rover called me back today after further investigations they said that the car needs a full new head unit. They are quoting a total of £1918 for the full repair. Although the parts guy is trying to get me a discount on the labour. The head unit is around £1000. What do you guys think regarding this?
They said we have removed the seat and the head unit etc and there is a fault within.
Post #585095 Thu Aug 08 2019 1:42pm
Brit Plumber
Pm me your VIN and I’ll get the part number (unless you know it) and see what eBay has. In my experience a second hand unit from a reputable dealer is £120 to £200, fitting in. L320 is about 15 to 20 minutes so I expect your car to be similar. 2019 5.0 SC SVA (Current)
Post #585097 Thu Aug 08 2019 1:59pm
