Home > General > 2015 RRS Blank Entertainment screen |
Lee1977 Member Since: 14 Jul 2015 Location: London Posts: 65 |
if you purchased from a dealer I would take it back to to dealer to resolve assuming its under warrenty Current RRS MY2012 HSE Lux 3.0 SDV6 Orkney Grey
Sun Jul 21 2019 6:46am |
eazy Member Since: 27 Jan 2010 Location: Scotland Posts: 122 |
Hi mate i bought the car privately and unfortunately out of warranty now! |
Sun Jul 21 2019 6:56pm |
Hi thought that you just have bought privatley but did not want to assume.
Sun Jul 21 2019 7:11pm |
Have you checked your fuses?
Sun Jul 21 2019 7:30pm |
Quick update, just had it in at land rover where they used a hour on the car. Called me back today and are asking for permission for another 4 hours because they believe the fault isn between head unit and amp.. £156 a hour though so before they even fix the problem its going to be £780 odds without any additional parts ontop. Any opinions guys? |
Wed Aug 07 2019 7:53am |
So they are implying it’s a wiring issue or MOST. MOST should be easy to diagnose as it’s a loop, if it’s broken, it doesn’t work.
Wed Aug 07 2019 8:18am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Have a feeling the Amp is under the front passenger's seat, not sure if possible but might be worth having a look to see if connections have been knocked in some way by rear seat passenger.
Wed Aug 07 2019 8:29am |
Thanks for the replys guys! So basically they want to strip it down from the amp to the headunit and test the wiring and see where the fault is, basically saying 5 hours labour + any parts needed ontop. Also they couldn't garuntee it would be fixed. im absolutely confused with it! |
Wed Aug 07 2019 5:32pm |
You shouldn’t need to strip the car to test wiring! It’s a 30 minute job to do a continuity and insulation test. I have a suspicion they know there is an issue and need to get to it.
Wed Aug 07 2019 6:19pm |
Can you read this?
Wed Aug 07 2019 6:28pm |
Once again, thanks for replys, the screen is absolutely blank. No symbol comes on at all and no radio audio or parking sensors work. The buttons at the sides of the nav light up and can be pushed but dont respond! Tried fuses and hard resettong car also. Hard lne ! |
Wed Aug 07 2019 6:32pm |
Another possibility.
Wed Aug 07 2019 6:44pm |
Land rover called me back today after further investigations they said that the car needs a full new head unit. They are quoting a total of £1918 for the full repair. Although the parts guy is trying to get me a discount on the labour. The head unit is around £1000. What do you guys think regarding this?
Thu Aug 08 2019 1:42pm |
Pm me your VIN and I’ll get the part number (unless you know it) and see what eBay has. In my experience a second hand unit from a reputable dealer is £120 to £200, fitting in. L320 is about 15 to 20 minutes so I expect your car to be similar. 2019 5.0 SC SVA (Current)
Thu Aug 08 2019 1:59pm |
