Home > General > Instrument cluster repair guide
wilchesth
United Kingdom 2008 Range Rover Sport TDV6 SE Zermatt Silver
Hi guys,
It seems that a lot of range rover sports L320 suffer from instrument cluster failure that causes the radio, blowers and sat nav to shutdown while driving and also show hazard lights on. It also causes the car to not start showing HDC fault, park brake fault, and other random faults.
Has anybody here had the courage to open an instrument cluster and see what exactly goes wrong that can cause this failure? If anybody has had luck opening one up and see anything suspicious would be great to know. There are so many cases like this all over the web that surely somebody would be able to write a HOW TO guide. 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #580537 Wed May 08 2019 10:11pm
Brit Plumber
I think someone on the disco 4 site fixed theirs when they found dry joints to some of the soldered components. Not sure if that is the fault you refer to though. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580554 Thu May 09 2019 11:48am
wilchesth
Yes, that's the rumour dry joints, but I wouldn't know where to look. If everybody is having similar issues it must be on the same components. The question is which ones. 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #580556 Thu May 09 2019 11:56am
wilchesth
I found a Russian site with more info about the instrument cluster. Unfortunately it is in Russian.
https://www.drive2.ru/b/499836887549084441/ 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #580569 Thu May 09 2019 2:55pm
Brit Plumber
Try this
https://disco4.com/forum/instrument-cluste...ht=Cluster
This tells you where to look on the board
https://disco4.com/forum/instrument-cluste...ht=Cluster 2019 5.0 SC SVA (Current)
Post #580578 Thu May 09 2019 5:47pm
gogsy1956
I have a feeling unless you are seriously into your electronic repairs I would leave it to the professionals as you could easily make it ten times worse. There are companies out there that specialise in repairing these units for around the £150 mark,,, remove the unit, post it to them and they will turn it round in a day or 2,,,, unless you are local to them as some offer a workshop service whereby they remove the unit as well.
I'm sure one outfit was call totaltronics,, or something similar, I would Google " instrument cluster repair " and see what you get. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #580583 Thu May 09 2019 6:19pm
it is good advice that.
The circuit board is complex with fine pitch solder connections.
And what with the dash containing the imboliser key, think carefully of the way forward
Post #580585 Thu May 09 2019 6:29pm
wilchesth
PROBLEM SOLVED
I solved the problem with a cheaper alternative.
I did think it was a specialized job but the quotes I received to get it repaired were all between £200 and £260 plus I had to have no car for 5 days, which in my case it is a problem as it is my main and only car.
So I decided to translate the Russian website I mentioned earlier which basically says to reflow a couple of IC's (IC10 and 64F2638F20) which made me think that a local PCB assembler should have the right equipment and personnel to do it within an hour. So what I did was to take the cluster out, walk to my local PCB assembler and showed them the two ICs that needed reflow, one hour later I had my cluster back. Reinstalled it and 2 weeks later the problem never reappeared.
Post #581831 Tue Jun 04 2019 12:27pm
gogsy1956
Glad you've got it sorted,,, definitely was a good idea getting a professional to carry out the work. 2010 RRS, TDV8
22" overfinch
Post #581833 Tue Jun 04 2019 3:18pm
thanks for the feedback Thumbs Up
Post #581836 Tue Jun 04 2019 4:39pm
knwatkins
Great news! A handy tip for others Thumbs Up Kev
Post #581855 Tue Jun 04 2019 8:16pm
shorler
United Kingdom 2007 Range Rover Sport TDV8 HSE Chawton White
Is this the issue that causes the Hazards to flash, doors to lock and fault codes 'vehicle lean when cornering','HDC Fault', 'Parking break fault,'ABS Fault'.
I have fault codes that link to communication with instrument cluster and Body control module. I am also currently sorting out the sunroof drain leak onto cables so drying all this out but think I will try this next if this relates to the issues im having
Post #587024 Sun Sep 15 2019 7:10pm
wilchesth
I had all those symptoms except 'vehicle lean when cornering' and 'ABS fault'. I don't have a sunroof tho but technician said could have been a leak. Looked for leaks but found nothing. Cluster was my only option at the end. And it was the cluster. Thumbs Up 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #587029 Sun Sep 15 2019 9:12pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
As an electronics engineer I would certainly reflow the connectors, as vibration often causes problems there, but I'd be surprised if the two IC's needed reflowing.
(I'm not saying they don't particularly need it, if someone has done some in-depth anaylsis, just that I'm surprised.)
Post #587084 Mon Sep 16 2019 8:36pm
